:idiot::idiot::idiot:
That was the 1st box i ever made on that other thread, lol, i dont think i ever tried it out, hmm. but here are the real pics
The port looks extra small if you ask me.But its sposed to be 32hz
Now i'm not sure if i want to add in this extra piece right here are not, if i do i have to cut it at an angle because the subs depth is more than my ports length :Doh:
:idiot::idiot: Ply wood :idiot:
Did that even look like an 18in hole to u guys, ahh come on now
Oh and does this need bracing of coarse
That port looks way off. Crooked as hell. Straighten up the port and make it go further back and then bend it at a 90 degree angle if you have to. And if that's for 2 sx 18's then you will need way more port area.
its not nailed down, yet.
I dont have room to make the port any bigger.
And from what i calculated that is the correct port length, to make it 32hz.
The one piece is just something i was gonna add on, but prolly wont.
Was the plywood a dual 12 ?
Not much port area for 2 18's there pal.
yea, it was a dual 12.
I dont get how u can have more port area, but keep the same tuning?
I mean i can change every aspect of it x*x*x, but its still going to be the same? correct?
like now it is 3.5x25x6.8
ok i'll calc some more specs here,
4x20x5.66
5x25x11
^^i think that would be the maximum i could get since i only have 43.5 across the front, the subs would be touching prolly also.
I guess its not alot of port area because my width can only be 3.5-4
p.s.
Me getting flamed for no reason on CA.com about the box
http://forums.caraudio.com/vb/showthread.p...00&page=2&pp=15
Oh yea and how should i brace this thing.
someone suggested only the baffle, that is the piece where the subs go correct?
someone else suggested adding pieces to the wall.
I was thinking of just adding pieces to the sides where the box came together and maybe to pieces runing from top to bottom.
