Posted December 1, 200916 yr I am building a wall and still need to seal it off on the sides and wherever there is space in between the box and the car walls. Is there a cheaper more efficient method besides spray foam? I am asking this because I am going to need about 20 cans of spray foam, if not more. I have also heard that spray foam is hard to work with. If there is something that is about the same price but is easier to work with please let me know.Thanks!!!!
December 1, 200916 yr If You Want To Be Cheap You Could Do The Whole Riveted Plexiglass With Rubber Weatherstripping And Superglue Or Silicone Thing, Can Get A Little Messy Though. Of Course You May Not Have The Room For It.You Plan On Making It Permenent?
December 1, 200916 yr Author I don't plan on selling the car for 5 years because that is when I will be out of college =)
December 1, 200916 yr I Was Gonna Say You Could Weld A Frame In.You'll Have To Build A Frame Either Way, For The Plexi Method Use MDF. There Are Other Ways Though.
December 1, 200916 yr Author thats not gonna happen ahaahah. Is there anything else that I could use as fill? Like could I use maybe some polyfill to fill the major gaps and spray foam the rest and the outside area?
December 1, 200916 yr you could put some poly down where you are going to be spray in foaming that way when you go to spray it in it will protect the carpet and such from the foam. and when you go to take it out of the car it should be easy enough to just pull it out with out TOO much trouble.
December 1, 200916 yr Author I already layed out some fabric to protect the floor.Will the polyfill idea work?
