Posted December 17, 200916 yr What happens when u put a subwoofer made for a ported enclosure only, in a sealed box?
December 17, 200916 yr You end up with a driver that has a really crappy response compared to what it would be if it were in a box designed for it.
December 17, 200916 yr Author You end up with a driver that has a really crappy response compared to what it would be if it were in a box designed for it.but would it blow the sub with the correct rms?
December 17, 200916 yr You end up with a driver that has a really crappy response compared to what it would be if it were in a box designed for it.but would it blow the sub with the correct rms?How would it blow up a sub, please explain this one. A box doesnt damage a sub, the user and how it controls it messes up equipment.
December 17, 200916 yr Author You end up with a driver that has a really crappy response compared to what it would be if it were in a box designed for it.but would it blow the sub with the correct rms?How would it blow up a sub, please explain this one. A box doesnt damage a sub, the user and how it controls it messes up equipment.i meant would it mess up the sub meaning since its not in the correct box because a sealed box usually holds in the pressure from the speaker moving. please dont get offended, just a question i always thought about. and im going with 2 dc audio lvl4 xl 15s.
December 17, 200916 yr So your gonna throw 2 DC Level 4 XL 15"s in some sealed boxes, why? Can you even fit two in there and still have room for batteries, amps and air flow around the box?
December 17, 200916 yr One XL 15" in a proper ported box will be louder and sound better then two in a to small sealed box.
December 18, 200916 yr Hell maybe even one 10 in the right box. Complete waste of sub to mis-use it. And more importantly a complete waste of money. DON'T
December 18, 200916 yr It's going to have a terrible response. You're probably going to get an f3 of like 80 hz, meaning it will have no lows at all.
