Posted December 17, 200916 yr should i face my subs and port into the car or both to the rear. these are not the only two options but im looking for the best way to get the best sq for a daily driver.
December 17, 200916 yr should i face my subs and port into the car or both to the rear. these are not the only two options but im looking for the best way to get the best sq for a daily driver.SQ, you can not get SQ(true SQ) with more than thousands of watts; please use another description. For loudest then subs and port facing forward usually but it all comes down to testing , every vehicle and install is different. Please use the search function, this topic has been made about 3 times within this month.
December 17, 200916 yr Port And Sub To The Rear (General Cabin Gain Rule In Trunk Cars), You're Not Going For SQ Unless You Want To Mount A Console Enclosure Right Next To You Or Infront Of You.Edit: Some People Have Skewed Views Of What A SQ Setup Is. Multiple Drivers And Kilowatts Aren't SQ, You Just Don't Want Them To Sound Like Shit Or Off Axis. You Want A "Daily" Setup. Edited December 17, 200916 yr by BigCProductions99
December 18, 200916 yr Author Port And Sub To The Rear (General Cabin Gain Rule In Trunk Cars), You're Not Going For SQ Unless You Want To Mount A Console Enclosure Right Next To You Or Infront Of You.Edit: Some People Have Skewed Views Of What A SQ Setup Is. Multiple Drivers And Kilowatts Aren't SQ, You Just Don't Want Them To Sound Like Shit Or Off Axis. You Want A "Daily" Setup.dai meant daily, thanks for clearing up my question
