Posted December 21, 200916 yr i measured my trunk i dont know if i did it right ,from front to back its 46 inches the height is 19 iches and the length 42 inches and then more towards the back of the car trunk its 56 inches if youve seen a chrysler 300 trunk then you know what i mean.i wanted to know if i could fit 3 xcon 12s in there i know zero about boxes anything will help...thanks
December 21, 200916 yr i measured my trunk i dont know if i did it right ,from front to back its 46 inches the height is 19 iches and the length 42 inches and then more towards the back of the car trunk its 56 inches if youve seen a chrysler 300 trunk then you know what i mean.i wanted to know if i could fit 3 xcon 12s in there i know zero about boxes anything will help...thanksProbably not, did you make room for batteries and amps in those dimension.
December 21, 200916 yr Author the front section of my trunk is the longest its at 52 inched so i will do the amps there and batteries on the side so your right 2 15 inch would be it..whats the best way to get the sound into the cabin of the car i think putting your backseats is tacky what would you suggest?and also my factor doors in the front are 6x9 same with back woould that be enough highs when running two 15 inch fibtl or 15 inch xcons off the saz4500,still undecided on the woofer.i was thinking the kicker frontstage with the saz 100.4...
December 21, 200916 yr the front section of my trunk is the longest its at 52 inched so i will do the amps there and batteries on the side so your right 2 15 inch would be it..whats the best way to get the sound into the cabin of the car i think putting your backseats is tacky what would you suggest?and also my factor doors in the front are 6x9 same with back woould that be enough highs when running two 15 inch fibtl or 15 inch xcons off the saz4500,still undecided on the woofer.i was thinking the kicker frontstage with the saz 100.4...No speakers no size will be able to keep up over 4000watts of bass.
December 21, 200916 yr Author the front section of my trunk is the longest its at 52 inched so i will do the amps there and batteries on the side so your right 2 15 inch would be it..whats the best way to get the sound into the cabin of the car i think putting your backseats is tacky what would you suggest?and also my factor doors in the front are 6x9 same with back woould that be enough highs when running two 15 inch fibtl or 15 inch xcons off the saz4500,still undecided on the woofer.i was thinking the kicker frontstage with the saz 100.4...No speakers no size will be able to keep up over 4000watts of bass.well im not saying be louder im just saying will it sound decent
December 21, 200916 yr if u have the doors on an amp they should get loud and then just make sure u have a good headunit to set the speakers right and set the filters and crossovers on the amp. should sound fine, and then later down the road if its not good enough then u can order some aftermarket door speakers. i have 1 18" nightshade in my car and stock door speakers with no amp and the way i set it up through my indash it sounds fine to my likings.
December 21, 200916 yr Author if u have the doors on an amp they should get loud and then just make sure u have a good headunit to set the speakers right and set the filters and crossovers on the amp. should sound fine, and then later down the road if its not good enough then u can order some aftermarket door speakers. i have 1 18" nightshade in my car and stock door speakers with no amp and the way i set it up through my indash it sounds fine to my likings.no not stock bro i was telling him if i ran the saz 100.4 and two sets of the 6x9 kicker ks would it sound decent..thanks thoe
December 21, 200916 yr Stock speakers definitely wont cut it or sound good, especially amped. Yeah the 100.4 will be good but I suggest a nice set of components, but plan on spending some money on deadening to make the front stage have more of an effect.
December 21, 200916 yr Author Stock speakers definitely wont cut it or sound good, especially amped. Yeah the 100.4 will be good but I suggest a nice set of components, but plan on spending some money on deadening to make the front stage have more of an effect.what componets woud you suggest any in particular?and also when doing 4500 watts of bass in a car what exactly needs to be deadened is it just trunk and front doors or roof also?
December 21, 200916 yr Stock speakers definitely wont cut it or sound good, especially amped. Yeah the 100.4 will be good but I suggest a nice set of components, but plan on spending some money on deadening to make the front stage have more of an effect.what componets woud you suggest any in particular?and also when doing 4500 watts of bass in a car what exactly needs to be deadened is it just trunk and front doors or roof also?Deadening is mostly preference but you should deaden where you need to. First you need to find out where your panels are vibrating, flexing like crazy or resonating at and cure those areas then see if more is needed. Some do deaden the roof, doors, trunk area and floors of there car/suv.
