Posted December 21, 200915 yr when doing a system in a trunk whats the best way to get the sound intko the cabin so its not stuck just in the trunk?can you make a cut out in the rear deck?
December 21, 200915 yr alot of people take the rear speakers out if they are in the rear deck, or u can cut holes with like a hole saw. also, if ur back seats fold down thats probably the best way.
December 21, 200915 yr when doing a system in a trunk whats the best way to get the sound intko the cabin so its not stuck just in the trunk?can you make a cut out in the rear deck?Take your speakers out of your rear deck, tear apart your rear deck or do subs and port firing into cabin with it sealed off from the trunk.
December 21, 200915 yr Author when doing a system in a trunk whats the best way to get the sound intko the cabin so its not stuck just in the trunk?can you make a cut out in the rear deck?Take your speakers out of your rear deck, tear apart your rear deck or do subs and port firing into cabin with it sealed off from the trunk.jaycee so pretty much fire the port hole towards the hole cut out in the reaar deck .could u still aim the face of the subs towards the back of the car and port it towards the front dam i hop that made sense lol
December 21, 200915 yr You want your port on same side as subs or maybe subs facing rear and port on side but not port on the opposite end of subs. You will be fine no matter which way you face it, there is no way of going around the loss of having your subs in a trunk unless you buy a vehicle that doesnt have one. Everyone with a trunked system is going through the same thing you are, so its only so much you can do but it will still have an effect.
December 21, 200915 yr Author You want your port on same side as subs or maybe subs facing rear and port on side but not port on the opposite end of subs. You will be fine no matter which way you face it, there is no way of going around the loss of having your subs in a trunk unless you buy a vehicle that doesnt have one. Everyone with a trunked system is going through the same thing you are, so its only so much you can do but it will still have an effect.thanks jaycee
