What is the difference in using a AGM battery instead of a Gel battery when running a secondary battery for an audio system? If the Ah and Reserve Capacity are the same or very similar in both batteries, then how do they differ? shrug.gif
Edited by wof131s
I know nothing about either, but a quick google search came up with:
- AGM batteries excel for high current, high power applications and in extremely cold environments.
- Gel Cells use a thickening agent like fumed silica to immobilize the electrolyte. Thus, if the battery container cracks or is breached, the cell will continue to function. Furthermore, the thickening agent prevents stratification by preventing the movement of electrolyte. As Gel cells are sealed and cannot be re-filled with electrolyte, controlling the rate of charge is very important or the battery will be ruined in short order. Furthermore, gel cells use slightly lower charging voltages than flooded cells and thus the set-points for charging equipment have to be adjusted.
- Absorbed Glass Mat (AGM) batteries are the latest step in the evolution of lead-acid batteries. Instead of using a gel, an AGM uses a fiberglass like separator to hold the electrolyte in place. The physical bond between the separator fibers, the lead plates, and the container make AGMs spill-proof and the most vibration and impact resistant lead-acid batteries available today. Even better, AGMs use almost the same voltage set-points as flooded cells and thus can be used as drop-in replacements for flooded cells.
-Basically, an AGM can do anything a Gel-cell can, only better. However, since they are also sealed, charging has to be controlled carefully or they too can be ruined in short order.
The main rain reason why AGM over Gel: AGM is preferred when a high burst of amps may be required. In most cases recharge can be accomplished by using a good quality standard battery charger or engine alternator.
Ok AGM over Gel in audio systems, got it. Thanks for that bit of information.
