Posted December 23, 200915 yr does anybody no the max watts of the nightshade 12inch 2-ohm, and what is the rms of the 1-ohm?
December 23, 200915 yr does anybody no the max watts of the nightshade 12inch 2-ohm, and what is the rms of the 1-ohm?No matter the voice coil rating the rms will be the same on any subwoofer you buy out there. The rms is 1500, since you have to ask stick with 1500rms and you wont damage anything.
December 23, 200915 yr Author does anybody no the max watts of the nightshade 12inch 2-ohm, and what is the rms of the 1-ohm?No matter the voice coil rating the rms will be the same on any subwoofer you buy out there. The rms is 1500, since you have to ask stick with 1500rms and you wont damage anything. for 2 12"inch nightshades would u suggest a 3500d or the new 4500d? and what voice coil would u get. the 2-ohm or the 1-ohm? Edited December 23, 200915 yr by pitbull
December 23, 200915 yr does anybody no the max watts of the nightshade 12inch 2-ohm, and what is the rms of the 1-ohm?No matter the voice coil rating the rms will be the same on any subwoofer you buy out there. The rms is 1500, since you have to ask stick with 1500rms and you wont damage anything.for 2 12"inch nightshades would u suggest a 3500d or the new 4500d? and what voice coil would u get. the 2-ohm or the 1-ohm?For two nightshades, get the dual 1 ohm. A SAZ3500D would be plenty for those two.
December 24, 200915 yr Author does anybody no the max watts of the nightshade 12inch 2-ohm, and what is the rms of the 1-ohm?No matter the voice coil rating the rms will be the same on any subwoofer you buy out there. The rms is 1500, since you have to ask stick with 1500rms and you wont damage anything.for 2 12"inch nightshades would u suggest a 3500d or the new 4500d? and what voice coil would u get. the 2-ohm or the 1-ohm?For two nightshades, get the dual 1 ohm. A SAZ3500D would be plenty for those two.what kind of wiring would u recommend?
