i dont get it. i was doin an install on my friends car and the speakers werent working. I decided to take my eD9.2 out of the car and and switch the pg out to see if i hooked everything up correctly. Everything was fine. Now here is the problem. Once i put everything back in to my car and hooked everything up, i found out that both my amps wouldnt turn on. i checked the fuses, all fine, all the connections, fine also. the HU works.... but it seems that my amps wont turn on. What the heck happened?
No clue...but it has to be one of the things that you have just said you checked.
An underhood fuse.
Your power wire fuse
your ground
remote
  • Admin
another problem solved
