Posted December 23, 200915 yr The vehicle is a 2008 Kia Sorento LXThe enclosure was build by Audible Customs. It's tuned to 32HzThe Subs are SA-12sThe wiring is all Knu Kolossus Fleks. NOTE: This is a comparison pic from the 4 gauge I used in my last build.The amp is a SAZ-2000D purchased from the presale. The battery is a Batcap 2000.The box installed...I'm using an Eclipse headunit with nav and ipod. And lastly my bass remote.
December 24, 200915 yr Have you experimented with the subs and port firing back to see if you like that better than up?Looks good man. Edited December 24, 200915 yr by rmzsuzuki89
December 24, 200915 yr Author Good work, do you have. How is your volatage with that Batcap 2000?If I recall correctly, it manages to stay in the low 13s playing a 50hz tone with 5 second intervals on repeat for 30 seconds on 3/4 volume. On music, I don't experience anything below 13.5 on full tilt, but then again I don't play it loud for a very long time.Have you experimented with the subs and port firing back to see if you like that better than up?Looks good man. There wasn't much of an audible difference in the way the subs and port were facing, however the wife likes it because it saves truck space.
