Posted December 28, 200916 yr Sold my btl18 looking into getting 4 15 Havocs here or my dimensions. Can I get 4 15's in these dimensions 35Wx38Lx35H thanks for the help ahead of time
December 28, 200916 yr More than enough room. You can even make the entire box 1.5" thick and still have over 4 cuft per driver with 60 sqin of port per driver tuned to 32 Hz.That sounds like maximum space/volume. Are you going to do a wall type setup, or a box?
December 28, 200916 yr Author A box I need to change my sig I just got a 2000 denali an don't wanna ruin my interior with a wall. Was gonna wall the tahoe but got rid of it. when I order the subs you think you could help me with a box design. Thanks for your help Oh I see why you asked that now the height is only 25 sry bout that Edited December 28, 200916 yr by bamatahoe
December 29, 200916 yr I can definitely design a box. Shoudl not be a problem for a non-wall with (4) 15's.Brian
December 30, 200916 yr Author As soon as my taxes get back I'm gonna order from you Brian an would appreciate a box design help thanks an when I get started with the build will start a build log thanks
February 22, 201015 yr As soon as my taxes get back I'm gonna order from you Brian an would appreciate a box design help thanks an when I get started with the build will start a build log thanks3.75 cubes each, subs up, port back. 12square inches of port per tuned to 28hz. low end beast.
