Posted December 31, 200916 yr Currently I have a 15" Fi SSD in a ported enclosure with almost 4 cu. ft. It is by far an amazing subwoofer hitting very low notes and hitting them hard. Recently however, I bought another 175 x 4 wrms amp and 6.5" component set that I am currently installing. That leaves another two channels that can be filled up with two more speakers, and I'd rather not use it on rear door speakers. My current subwoofer, does not give the desire punch that I want, and I was wondering if I should buy two woofers or mid-bass/mid-range drivers. Will these give me that punch fill that I want in my system, or should I instead go with two 8" subwoofers for punch. Another question is what creates punch in bass, is it certain frequencies that smaller subwoofers can produce better? I have 175x2wrms at my disposal to create punch and would appreciate opinions on what type of speaker I should go with. Here is my system btw:-Pioneer P5100- 15" Fi ssd subwoofer -Sundown SAE 1000D amplifier- Cadence ZRS6K components-Cadence Xa175.4 amplifier (175x4wrms @ 2ohms & 110x4wrms @ 4 ohms)Car: 2004 Subaru Forester 2.5x
December 31, 200916 yr Author What is your boxed tuned to? What are your setting on amplifier?33hz, and i set the subsonic to about 50hz and the LPF to about 250HZ, they're amateruish settings I just did what sounded right.
December 31, 200916 yr What is your boxed tuned to? What are your setting on amplifier?33hz, and i set the subsonic to about 50hz and the LPF to about 250HZ, they're amateruish settings I just did what sounded right.Your subsonic should be set to around 30 hz or so, just a few hertz below the boxes tuning. Your LPF should be no higher then 80/100 hertz, depending on your preference.
December 31, 200916 yr Author What is your boxed tuned to? What are your setting on amplifier?33hz, and i set the subsonic to about 50hz and the LPF to about 250HZ, they're amateruish settings I just did what sounded right.Your subsonic should be set to around 30 hz or so, just a few hertz below the boxes tuning. Your LPF should be no higher then 80/100 hertz, depending on your preference.Thanks for that =) , actually was another question of mine that I've been wanting the answer to. Will this help create anymore punch jw?
December 31, 200916 yr Well you might be losing the punch you need with your filter so high, since it is canceling all the frequencies below 50Hz from my experience. Go out there and change the settings and let us know, if that doesnt work then there is another bad setting or problem with your setup. But it should do the job.
December 31, 200916 yr Author Well you might be losing the punch you need with your filter so high, since it is canceling all the frequencies below 50Hz from my experience. Go out there and change the settings and let us know, if that doesnt work then there is another bad setting or problem with your setup. But it should do the job.Makes sense, unfortunately I wont be able to hear my subwoofer for another couple days because I'm in the middle of installing components and a amp. However how would I go about adding more punch if I wanted to?
December 31, 200916 yr First we need to determine what punch you are talking about, what frequencies do you feel you are missing? It is hard to determine or answer that question accurately if you dont have the right settings on your subs to determine if it is them or not? Why cant you hear your subs, if your installing an amp and comps that dont have anything to do with the subs or subs amp?
December 31, 200916 yr Author First we need to determine what punch you are talking about, what frequencies do you feel you are missing? It is hard to determine or answer that question accurately if you dont have the right settings on your subs to determine if it is them or not? Why cant you hear your subs, if your installing an amp and comps that dont have anything to do with the subs or subs amp?Cars currently in pieces right now, with the receiver and paneling taken out so that I can run the new wires is all, plus to access my new amp i need the current subwoofer box taken out. I can hear the subs fine, its simply a different sound between a 15" and a 12" or 10", it has more punch, my guess would be those frequencies around 120hz maybe? I guess its somewhat hard to describe, and your right I need to first reconfigure my current settings before I can say anything else.
December 31, 200916 yr I might be wrong but to me it sounds like you need a harder hitting midbass driver for the "punch" above the frequency of the sub.
December 31, 200916 yr First we need to determine what punch you are talking about, what frequencies do you feel you are missing? It is hard to determine or answer that question accurately if you dont have the right settings on your subs to determine if it is them or not? Why cant you hear your subs, if your installing an amp and comps that dont have anything to do with the subs or subs amp?Cars currently in pieces right now, with the receiver and paneling taken out so that I can run the new wires is all, plus to access my new amp i need the current subwoofer box taken out. I can hear the subs fine, its simply a different sound between a 15" and a 12" or 10", it has more punch, my guess would be those frequencies around 120hz maybe? I guess its somewhat hard to describe, and your right I need to first reconfigure my current settings before I can say anything else.Well yeah thats a little high for your subwoofer to be playing, I would lower it to about 100Hz for now and look at where you can install some components or midbass drivers to compensate for 100Hz on up.
December 31, 200916 yr Author First we need to determine what punch you are talking about, what frequencies do you feel you are missing? It is hard to determine or answer that question accurately if you dont have the right settings on your subs to determine if it is them or not? Why cant you hear your subs, if your installing an amp and comps that dont have anything to do with the subs or subs amp?Cars currently in pieces right now, with the receiver and paneling taken out so that I can run the new wires is all, plus to access my new amp i need the current subwoofer box taken out. I can hear the subs fine, its simply a different sound between a 15" and a 12" or 10", it has more punch, my guess would be those frequencies around 120hz maybe? I guess its somewhat hard to describe, and your right I need to first reconfigure my current settings before I can say anything else.Well yeah thats a little high for your subwoofer to be playing, I would lower it to about 100Hz for now and look at where you can install some components or midbass drivers to compensate for 100Hz on up. yea so i was thinkin of going with CVLW either the 10" or the 8" speakers, but I would like to know of any other brands that sell midbass speakers, where else I can look.Another possibility is the Dynaudio Esotec MW 172 Edited December 31, 200916 yr by bedbreath
December 31, 200916 yr If you want better punch, you need a midbass. However, I'd wait until after you correct the crossover settings on the sub and install the new components, as those may give you the better results. If not, what you might want to look into doing is an 8" midbass (not subwoofer) in the front door if you can find the room. If you get to that point we can help you with what you'll need to do that.
December 31, 200916 yr I'd still like a better definition of punch as I'd bet the fix is simpler than adding anything but instead focusing on fixing what you have.
December 31, 200916 yr Author If you want better punch, you need a midbass. However, I'd wait until after you correct the crossover settings on the sub and install the new components, as those may give you the better results. If not, what you might want to look into doing is an 8" midbass (not subwoofer) in the front door if you can find the room. If you get to that point we can help you with what you'll need to do that.That is exactly what I was thinking, getting a pair of 8" midbass drivers, I will wait until the install is complete, and keep you updated to see if my car still lacks. As for what exactly is punch..., I still can't describe it and was hoping someone could help me define it. All I can say is its that deference between the bass you hear in a 15" sub in comparison to a 10" or 12" sub.
December 31, 200916 yr I agree with KU40, it sounds like you want more midbass and are expecting it from the subwoofer. Assuming this due to the high crossovers and the OP saying the lows sounded great. You'll likely notice a world of difference once the subsonic filter is lowered to ~30hz and LPF to ~100/120hz.
December 31, 200916 yr If you want better punch, you need a midbass. However, I'd wait until after you correct the crossover settings on the sub and install the new components, as those may give you the better results. If not, what you might want to look into doing is an 8" midbass (not subwoofer) in the front door if you can find the room. If you get to that point we can help you with what you'll need to do that.That is exactly what I was thinking, getting a pair of 8" midbass drivers, I will wait until the install is complete, and keep you updated to see if my car still lacks. As for what exactly is punch..., I still can't describe it and was hoping someone could help me define it. All I can say is its that deference between the bass you hear in a 15" sub in comparison to a 10" or 12" sub.The reason why you think it is a difference in sound between your 15" and 10" or 12" is because of your settings more than likely, when your done installing get at us and we will be able to help you if you still need it. Good luck with install and dont forget to take pictures and post a build log for us.Pictures on SSA =
January 4, 201016 yr Author If you want better punch, you need a midbass. However, I'd wait until after you correct the crossover settings on the sub and install the new components, as those may give you the better results. If not, what you might want to look into doing is an 8" midbass (not subwoofer) in the front door if you can find the room. If you get to that point we can help you with what you'll need to do that.That is exactly what I was thinking, getting a pair of 8" midbass drivers, I will wait until the install is complete, and keep you updated to see if my car still lacks. As for what exactly is punch..., I still can't describe it and was hoping someone could help me define it. All I can say is its that deference between the bass you hear in a 15" sub in comparison to a 10" or 12" sub.The reason why you think it is a difference in sound between your 15" and 10" or 12" is because of your settings more than likely, when your done installing get at us and we will be able to help you if you still need it. Good luck with install and dont forget to take pictures and post a build log for us.Pictures on SSA = Alright Well I've just Installed the new speakers and I properly set the filters on the subwoofer which I can say sounds a decent amount better now. However from installing the new speakers I have several new problems now... here goes:-Have some bad peaks and valleys-Lots of rattling now =S-Speakers clip when I set the gain past a certain level even with volume completely off, preventing me from properly setting the gain-Speakers are picking up a lot of outside noisewhew so yea, it need some fixing. The speakers picking up outside noise is from using home audio wires... yea poor choice but it was what was readily available and I didn't think it make much of a difference... I was wrong lol. And of course my car needs to be sound dampened to cancel out the rattling. I think the speakers also need to break in first to help smooth out the peaks and valleys that I hear currently. As for the clipping I have no idea why its doing such, thats where I need some help on. The punch has gotten better, still slightly lacking for my tastes but I can definatly make due with it for now, but still am interested in buying mid-bass speakers later on. So that's the update.
January 5, 201016 yr There can't be clipping with the volume completely off. Are you hearing noise with the volume all the way down? That's signal interference from other electronics and things in the car.
January 5, 201016 yr Author There can't be clipping with the volume completely off. Are you hearing noise with the volume all the way down? That's signal interference from other electronics and things in the car.They're popping then, being pushed to their maximum and just move in and out making a loud obnoxious noise which is sudden once I pass a certain gain volume on the amp, my left speaker did this before until i switch up the terminal (which was already correct anyways). I already hear the signal interference, and thats not whats causing it because the interference does not get amplified.
