Posted January 5, 201015 yr Ok so i might be building a sub box for my truck. It is a 2000 f250 SuperDuty. I have stock electrical. I have alpine type r 5x7 all around I have pioneer hu. I need help in choosing subs. I plan on putting 3 10's my budget is spending around 200 for speakers and 50 for the materials for the boxi have this so far top depth 3 3/4 'bottom depth 6 1/4'length 52'height 16'should i do ported or sealed???? Edited January 5, 201015 yr by cheese20323
January 5, 201015 yr Well that space is only about 2 cubes before any displacements. You cannot do three 10s ported in that space. You probably couldn't even do two 10s ported, maybe one twelve ported would work. So your choice is pretty much sealed unless you'd consider lowering the number of subs. They'll need to be pretty shallow, probably only a 4.5" mounting depth.
January 5, 201015 yr Author Well that space is only about 2 cubes before any displacements. You cannot do three 10s ported in that space. You probably couldn't even do two 10s ported, maybe one twelve ported would work. So your choice is pretty much sealed unless you'd consider lowering the number of subs. They'll need to be pretty shallow, probably only a 4.5" mounting depth.oh well i was looking to see if it would be better ported or sealedmy budget would be around 250 to 320 $. There is no way that i could fit different subs other than shallows. Or is there any good sounding shallows. Can i move my back bench seat a little forward so i can build a different box with more mounting depth.
January 6, 201015 yr pair of 8's or one 12 with the correct size box, ported can get pretty dam,n loud in a truck cabin.What amp do you have?
January 6, 201015 yr Author pair of 8's or one 12 with the correct size box, ported can get pretty dam,n loud in a truck cabin.What amp do you have?write now i have the us amps xt2000d 1000wrms @1ohmand the us amps 800.4 100x4wrms @ 2 ohmstock electrical and a 2 farad capacitor4 awg wiring and pioneer HU
January 6, 201015 yr Two Incriminator 187 10's ported behind the back seat is going to be the best set-up for your budget
January 6, 201015 yr pull out the plastic vents on the back wall and cover them with sound deadener. ( there is some factory material on the back wall behind the carpet you can use) Make the enclosure 52" wide, as tall, and as deep as the 10's. Put the subs on the passenger side and the port on the driver side. The port should be around 1.5 wide, 10.5 tall, and around 29 long for tuned to 34 hertz. Using 1/2 inch mdf
January 6, 201015 yr Author Two Incriminator 187 10's ported behind the back seat is going to be the best set-up for your budgetyeah but would they fit in the box???
January 6, 201015 yr Author tes sir I have done severalso what your saying is take off the back plastic part. Cover that with Dynamat or any other sound deadener. And that would be good. Do u think the re srx would fit there or the 187's are better?? Ive never tried incriminator audio but i have tried re audio Edited January 6, 201015 yr by cheese20323
January 6, 201015 yr there two vents on each corner on the back wall about 4x6 inches each. They will have to come out to fit the enclosure. This will leave a whole in the back wall which will need to be covered so water doesn't get into the cabin. And yes I would take IA over RE
January 6, 201015 yr Author there two vents on each corner on the back wall about 4x6 inches each. They will have to come out to fit the enclosure. This will leave a whole in the back wall which will need to be covered so water doesn't get into the cabin. And yes I would take IA over REJust for info i have the Superduty without window motor. Oh ok so i wont need that much sound deadner. How much do you sell the 187's shipped to 92567 10"s.
January 6, 201015 yr My pricing is the same as SSA. I am so swamped right now it would be faster to order it from Mark.
January 6, 201015 yr Author My pricing is the same as SSA. I am so swamped right now it would be faster to order it from Mark.Ok going to make like a little diagram of cheap wood see if they would fit. This will work on the four door right??? Edited January 6, 201015 yr by cheese20323
January 23, 201015 yr Author yea this if for the four door. It's a perfect fitI know this thread is a little old but i made a little thingand this is what i can fit 4 3/4 at the top6.5 at the bottom14 inches tall 52 inches long how much mounting depth should i have 'another decision two SA-8's or 2 10 IA 187's Is there specific db's for hairtricks????Should i go ported or sealed i just want to know if there is a specific db for hairtricks it is not a goal
