Posted January 5, 201015 yr I currently have an mb quart dsc 4125 for 2 peerless sls 8's(does 500 x 2 bridged) sundown 100.4(tang bang mids & alpine tweets) and a sundown 3000 for 2 xcon's. I was doing some measurements in the trunk of my acura tl while laying down deadening and there's no way to fit those 3 amps, 4 cube box, and a big battery so i need smaller footprint amps. what i need is1 4 channel that can do 300+ bridged @ 4 ohms(pdx is an option, though i'd like something smaller)1 4 channel that can do 100-125 x 4 @ 4 ohms(may pick up an arc audio mini) 1 mono amp that can do 3000-3300 @ 1 ohm
January 5, 201015 yr You will be able to find a smaller footprint amp for this first two options but for the mono amp I doubt you will find a 3000 or better @ 1ohm with a small footprint.
January 5, 201015 yr Author Anything smaller than the sundown that i can use? I really don't wanna mount it to the box, and it won't fit on the seatback.
January 5, 201015 yr Actually I did find you one, spoke to soon:http://www.stetsom.com.br/eng/DetalhesProduto.aspx?c=7836&cat=172I mounted mine to the box in the past (and will do in the future) with no problems as along with others on this page. Not trying to persuade you to do it but if you do good bracing and put some foam pads under your amps feet you will be fine (just an option).
January 5, 201015 yr Author I'm gonna try box mounting and see how it goesi was always told not to box mount due to parts coming loose over time.Thanks for the link to the stetsom
January 5, 201015 yr I'm gonna try box mounting and see how it goesi was always told not to box mount due to parts coming loose over time.Thanks for the link to the stetsomTo me its a personal preference and to each its own, just build a sturdy box and follow the tips in my previous post. You will be good put up a build log when you start the install.
January 5, 201015 yr I used rubber grommets and padding under my amp (Sundown SAZ-1500D) when I mounted it to the box (2-Incriminator LI 15's). I had it like that for over a year without any issues and plan on doing the same with the new box for the 4/SA-8's.
January 5, 201015 yr Author I'm gonna try box mounting and see how it goesi was always told not to box mount due to parts coming loose over time.Thanks for the link to the stetsomTo me its a personal preference and to each its own, just build a sturdy box and follow the tips in my previous post. You will be good put up a build log when you start the install.I'm having a shop install everything..i'll ask them take pics of the install, though. I used rubber grommets and padding under my amp (Sundown SAZ-1500D) when I mounted it to the box (2-Incriminator LI 15's). I had it like that for over a year without any issues and plan on doing the same with the new box for the 4/SA-8's.I'll take that into consideration.
January 5, 201015 yr I'm having a shop install everything..i'll ask them take pics of the install, though.
January 5, 201015 yr Author I'm having a shop install everything..i'll ask them take pics of the install, though. I don't have the space, tools, or the knowledge to install this stuff..this is what's going inkenwood dnx 91402 peerless sls 8's fiberglassed in the doorstang bang mids and alpine spx tweets in the apillars2 12" xcons in 4 cubes ported1 maybe 2 Deka Intimidator 9a31 battsI also work 60-70 hrs a week so no time for install..
January 5, 201015 yr Expect the shop to butcher the hell out of your active settings.* I don't see a processor in your list either, you are going to need one.
January 5, 201015 yr I'm having a shop install everything..i'll ask them take pics of the install, though. I don't have the space, tools, or the knowledge to install this stuff..this is what's going inkenwood dnx 91402 peerless sls 8's fiberglassed in the doorstang bang mids and alpine spx tweets in the apillars2 12" xcons in 4 cubes ported1 maybe 2 Deka Intimidator 9a31 battsI also work 60-70 hrs a week so no time for install..You better find a VERY good down to earth shop then.
January 5, 201015 yr Author Expect the shop to butcher the hell out of your active settings.* I don't see a processor in your list either, you are going to need one.forgot to add the rockford 3sixty 2 to the list You better find a VERY good down to earth shop then.I'm still lookin' around for good shops in tri state area
January 5, 201015 yr you should sell your sax100.4 to me. And get the incriminator audio 6.4 4-channel. It has a small footprint and is powerful.
