Posted January 6, 201016 yr well i got my SAZ 1500d in the mail a few days ago... and now i have my 1/0 gauge Tsunami amp kit to replace the 4 gauge from my old sub amp... so now i am getting ready to install it all, i was just wondering if anyone had any good sugestions on where to set the subsonic and the LPF knobs ? and i a guessing to leave the phase off.. this amp is to run my 15" Xcon.. it is in a 4 cubic feet box ported to 32 hz.... i figured there would be someone here who could get me close..
January 6, 201016 yr set your subsonic for about 27hz or 28hzas for the LPF most people say to put it at around 80hz. but mine isn't. i just played with it until it sounded right. so you could try that way as well
January 6, 201016 yr Low Pass anywhere from 60/80/100 hz depending on what you like and if you have midbass and where they are set at.Play around with the phase to see what you like but some leave it alone.Be sure to set your gain with a DMM, not the best or accurate way unless you can tell signs of stress on a woofer.
January 7, 201016 yr set your subsonic for about 27hz or 28hzas for the LPF most people say to put it at around 80hz. but mine isn't. i just played with it until it sounded right. so you could try that way as wellYep, I have my sub xover set at 80Hz too.
