Posted January 11, 201016 yr I recently installed an inexpensive amp (Pyramid 4 channel 1600w) for the 4 mids and highs but now have a noise when ever I turn up the gains of this amp.I have a noise filter on the positive lead to the radio but still have this.Can this be from the cheap amp or the Iraggi alternator?It was not there before.Any ideas???Thanks,JR
January 11, 201016 yr I recently installed an inexpensive amp (Pyramid 4 channel 1600w) for the 4 mids and highs but now have a noise when ever I turn up the gains of this amp.I have a noise filter on the positive lead to the radio but still have this.Can this be from the cheap amp or the Iraggi alternator?It was not there before.Any ideas???Thanks,JRI have heard where the ho alternator could be a problem but I would suggest you check your amp and headunits grounds (they me be bad).
January 11, 201016 yr Author I recently installed an inexpensive amp (Pyramid 4 channel 1600w) for the 4 mids and highs but now have a noise when ever I turn up the gains of this amp.I have a noise filter on the positive lead to the radio but still have this.Can this be from the cheap amp or the Iraggi alternator?It was not there before.Any ideas???Thanks,JRI have heard where the ho alternator could be a problem but I would suggest you check your amp and headunits grounds (they me be bad).Hey Jay-cee,Wassup. How were the holidays? Hope all that is good come your way this year.The amp is connected directly to the batt and so is the radio. You suggest another ground directly to the body?. I already have the big 3 done. This is why I'm lost..
January 11, 201016 yr Make sure the grounds for everything (battery, head unit, amp, etc.) have a very good ground with the paint sanded off.Sometimes cheap amps pick up noise easier than higher quality amps. If the amp is all you changed and the wires and everything stayed the same as the previous amp, the amplifier seems to be the biggest suspect. But try redoing the grounds as well. If all else fails you can get a ground loop isolator to put on the RCAs.
January 11, 201016 yr Author Make sure the grounds for everything (battery, head unit, amp, etc.) have a very good ground with the paint sanded off.Sometimes cheap amps pick up noise easier than higher quality amps. If the amp is all you changed and the wires and everything stayed the same as the previous amp, the amplifier seems to be the biggest suspect. But try redoing the grounds as well. If all else fails you can get a ground loop isolator to put on the RCAs.ok...will redo all this afternoon.I am not using the RCA's for input but the speaker wires coming from the radio.Thanks,JR
January 11, 201016 yr Author Make sure the grounds for everything (battery, head unit, amp, etc.) have a very good ground with the paint sanded off.Sometimes cheap amps pick up noise easier than higher quality amps. If the amp is all you changed and the wires and everything stayed the same as the previous amp, the amplifier seems to be the biggest suspect. But try redoing the grounds as well. If all else fails you can get a ground loop isolator to put on the RCAs.ok...will redo all this afternoon.I am not using the RCA's for input but the speaker wires coming from the radio.Thanks,JRRechecked all wires. From battery to radio to amp to speakers and back.Even installed an additional ground directly from the radio to the chassis of the car but the damn noise is still there.What a pain in da butt...Question.I did blow a fuse over the weekend by a short that I accidentally made.Could this have damaged the noise filter in anyway??Maybe I should try an additional noise filter..what do you think??
January 15, 201016 yr Author Good call!!!Figured out what was causing the noise.Swapped the Amp out for another Hifoincs and also used shielded RCA cables.Noise and whine are gone.Awesome. Edited January 15, 201016 yr by Hanapi
January 15, 201016 yr Glad to see you got it working, yeah those cheap amps and headunits will be the cause most of the time.
January 16, 201016 yr Author Yup,That will teach me to skim on the rest of the system.Big difference.Am thinking of adding another amp and adding two more mids and highs tomorrow.Hope to fine tune it. This stuff is in an E-350 Van so I have a big area to fill.
January 16, 201016 yr Yeah trust me I have been there on the skimping idea just to get by and where I skimped at years ago is still causing me to spend money till this day to do it right. Now it is do it right or dont do it all, glad we could be of some assistance.
