Posted January 12, 201016 yr picked up a pair of 12" iCons and this is the box I plan to build. I was wondering what you guys think. This is the first time I have run anything other than a single 15" or a single 18" so I want ot get opinions before I build it.4.8ft^3 net air space (5.12ft^3 gross .16ft^3 displacement per sub)tuning 32hz-33hz72.5in^2 port area Edited January 12, 201016 yr by k_schutte
January 12, 201016 yr Did you remember to subtract port displacement from the net volume as well? Or are you using external ports?
January 12, 201016 yr Author Did you remember to subtract port displacement from the net volume as well? Or are you using external ports?The picture I posted shows how I did it. the port area was subtracted, total gross for teh box was like 7.7ft^3 before port, wood and subwoofer displacement...
January 12, 201016 yr I'd be wary of that design it doesn't quite add up right. Just at a quick glance the port width is 5" but at the back wall it is only 4.5".
January 13, 201016 yr Did you remember to subtract port displacement from the net volume as well? Or are you using external ports?The picture I posted shows how I did it. the port area was subtracted, total gross for teh box was like 7.7ft^3 before port, wood and subwoofer displacement...Ah, I couldn't see that there were pictures because I was at work the first time I viewed the thread and the network there usually blocks pics.
January 13, 201016 yr I'd be wary of that design it doesn't quite add up right. Just at a quick glance the port width is 5" but at the back wall it is only 4.5". Its 4.5" LENGTH after the corner of the port. Not width. It's stilll 5" wide. Nice design!
January 13, 201016 yr I'd be wary of that design it doesn't quite add up right. Just at a quick glance the port width is 5" but at the back wall it is only 4.5". Its 4.5" LENGTH after the corner of the port. Not width. It's stilll 5" wide. Nice design!Not talking about the length that is given.15.25" port wall + .75" for the second wall = 16" 20.5" of internal depth - 16" = 4.5" away from the rear wall. Not to mention if it was 5" from the back it would be tuned to 34hz
January 13, 201016 yr I'd be wary of that design it doesn't quite add up right. Just at a quick glance the port width is 5" but at the back wall it is only 4.5". Its 4.5" LENGTH after the corner of the port. Not width. It's stilll 5" wide. Nice design!Not talking about the length that is given.15.25" port wall + .75" for the second wall = 16" 20.5" of internal depth - 16" = 4.5" away from the rear wall. Not to mention if it was 5" from the back it would be tuned to 34hzI follow you, you're right.Aren't straight ports better than the L shaped one's?Straight ports become L-shaped ones when they don't fit in the box depth-wise.
