Posted January 14, 201016 yr What do you guys think would be best for 2 fi Bl 18" box wise.26"H x 37"W x 30"D giving it 14 cubic feet24"H x 36"W x 40"D giving it 17 cubic feet24"H x 34"W x 45"D giving it 18 cubic feetI am going to be getting 2 AQ1200d for each sub. I want it to hit pretty hard. I will be posting up some pics of the build that will get chosen the most. Thanks!
January 14, 201016 yr What do you guys think would be best for 2 fi Bl 18" box wise.26"H x 37"W x 30"D giving it 14 cubic feet24"H x 36"W x 40"D giving it 17 cubic feet24"H x 34"W x 45"D giving it 18 cubic feetI am going to be getting 2 AQ1200d for each sub. I want it to hit pretty hard. I will be posting up some pics of the build that will get chosen the most. Thanks!How bout making this topic after you added in port volume, sub displacement, bracing and so on.
January 14, 201016 yr Why does it matter?? Am I hurting you?? If I am sorry No your not hurting me and yes it matters, why would someone say this box is better when we dont have all the box's specs. If you want to know which is better off of dimensions then the one that fits nicely and has the amount of space you want leftover once the box is in. Why do people get emotional, it is just a post take your skirt off. It doesnt make sense if there is not enough information to make an accurate judgment. Please read new member guidelines before posting again, none of your topics follow those guidelines. Thanks.
January 14, 201016 yr What do you guys think would be best for 2 fi Bl 18" box wise.26"H x 37"W x 30"D giving it 14 cubic feet24"H x 36"W x 40"D giving it 17 cubic feet24"H x 34"W x 45"D giving it 18 cubic feetI am going to be getting 2 AQ1200d for each sub. I want it to hit pretty hard. I will be posting up some pics of the build that will get chosen the most. Thanks!two AQ 1200 per BL?
January 14, 201016 yr It's just a website.That we take seriously. And if you want US to take YOU seriously, you really need to go read the noobie posting guides. You're not going to get much help with a topic like this.
January 14, 201016 yr Author AQ1200 1 sub AQ1200 1 sub equal 2 subs and 2 amps Edited January 14, 201016 yr by Technology
January 14, 201016 yr AQ1200 1 sub AQ1200 1 sub equal 2 subs and 2 amps well that makes perfect sense now. Look how you posted earlier
January 14, 201016 yr What do you guys think would be best for 2 fi Bl 18" box wise.26"H x 37"W x 30"D giving it 14 cubic feet24"H x 36"W x 40"D giving it 17 cubic feet24"H x 34"W x 45"D giving it 18 cubic feetI am going to be getting 2 AQ1200d for each sub. I want it to hit pretty hard. I will be posting up some pics of the build that will get chosen the most. Thanks!i'll help.
January 14, 201016 yr Author Thanks bro. So which box you think looks good or do you have different specs?
January 14, 201016 yr just like everybody has said, u really need to tell us what ur wanting ur system to do. u also need to figure in ur port area and bracing into those sizes...we cant really tell u anything from the dimensions u gave us.
January 14, 201016 yr Author I want to get a box like this bro.http://www.youtube.com/user/03blackAck1028#p/u/5/WI7bXhiMjKQ
January 14, 201016 yr I want to get a box like this bro.http://www.youtube.c...u/5/WI7bXhiMjKQIt's a simple box !Don't make it too big for your trunk.I think you should not have the ports too close of the trunk lid like this one. When this guy close the trunk, he has quite a sealed box !!!That is why I choose to make the sub and the port UP in my trunk.But talk to some gurus here, 'cause I am not a box designer/expert !
