The 15 inch BL box recommendations are (BL 15 – Ported box we recommend using 2.8-4 cubic feet @ 28-37Hz. Again use 12-16 square inches of vent area per cubic foot of volume) Im not exactly sure what size and hz i should tune my box to. I have one 15 BL fully loaded ment for daily personal use. Any recommendations on what will give my the best bang for my buck?
  • 2 weeks later...
i would make a 3.5 cu ft box tuned to 33 hz and use 14 SQUARE inches of port witch just means 1 inch wide 14 inches long per cu ft of airspace or 7x2 and so on. use a box calc if you have to good luck great sub
how much space you have to work with? and ask your self if you want it deep turn around 28 and lower or do you want it loud...
well if your close to indiana ill just sell you my box i got two of them now
box sounds great
