Posted January 27, 201016 yr so im looking at some two way 6.5" component systemsIf im only doing front stage, i still need a four channel amp, right?2 channels for the two 6.5's, and 2 for the tweets?i just want to make sure because i'm trying to take advantage of the amps on db-r before they are gone.... thanks!
January 27, 201016 yr so im looking at some two way 6.5" component systemsIf im only doing front stage, i still need a four channel amp, right?2 channels for the two 6.5's, and 2 for the tweets?i just want to make sure because i'm trying to take advantage of the amps on db-r before they are gone.... thanks!If your gonna run them active then yeah you will need a 4 channel amp but if your gonna use the crossovers that come with speakers then you will only need a 2 ch. amp.
January 27, 201016 yr Author ah excellent. thanks for clearing up the confusion. I had read people running them with a 2 channel, and other people running with a 4. Thank you!
January 27, 201016 yr Not a problem at all, your gonna have to give me a review on that battery when you get it in and installed since Im curious on how the Shuriken batteries hold up.
January 27, 201016 yr Author yeah will do for sureI was hoping to get a kinetik but no one has them and i just learned that they are moving all their warehouses and production plants?? or something like that? that's what wooferect.com told me, so im literally ordering the shuriken right now. I figured it was a comparable replacement
January 27, 201016 yr Yeah I heard they are replacement from a shop owner who swiched out to them from the Kinetiks, but the only way is to test rather then speculate like most will.
