Posted July 3, 200521 yr i need some mid's with killer midbass, enough to blend in well with my horns and ported idmax.here are my amp specs:MA Audio m283i 2ch# Frequency Response: 20 Hz - 20 kHz# Full Mosfet Circuitry# Selectable Bass Boost @ 50Hz# 50dB Channel Separation# 90dB Signal Noise Ratio# 22K Ohm Input Impedance# 200mV-2V Input Sensitivity# THD <0.05%# Selectable Crossover: LPF, FLAT, HPF# 50Hz - 250Hz Low Pass Filter# 50Hz - 250Hz High Pass Filter# Selectable Bass Boost (0db, 6dB, 12dB)# 2 x 100W Rms @ 4 Ohm Stereo# 2 x 200W Rms @ 2 Ohm Stereo# 1 x 400W Max @ 4 Ohm Bridged# Fuse Rating: 25A x 1could yall suggest something? theyre most likely gonna be in the doors IB (although i may eventually make sealed doorpods). budget is $200 give or take. should be a 6.5-7". mounting depth isnt a concern. used is fine. thanx.
July 3, 200521 yr Author thanx.aww how come though? after spending all that time making those sweet doorpods.
July 3, 200521 yr Author hmm i think im gonna go with either xxx's or extremis'.now based on my amp, which should i go with yall?help me out here please anyone have any idea when the 4ohm extremis will be out?
July 3, 200521 yr Go to the other good forum and search. Lot of good mids on there, particularly the budget minded Seas at $50 a pop.
July 5, 200521 yr HEy check out the EU-700 from eD they are on preorder rite now and ben said they will be done any day now. Just don play them over 1khz.
July 5, 200521 yr Author some get that bile taste in their mouth when it comes to eD and pre-order.<{POST_SNAPBACK}>lolanyways, i've decided on the extremis. emailed wiggins and he said they would work just fine in the doors off of as little as ~30wrms. looks like i'm gonna have some fun with that mounting depth he said that they should start being a little bit more on axis if crossing them higher, but mine will be crossed between 1-2hkz so i'm fine with in the doors.
July 7, 200521 yr Take a look at these. Great price as well. http://www.diymobileaudio.com/forum/viewtopic.php?t=288KaliEdit: Sorry just realized you went with the Extremis. Enjoy!
July 7, 200521 yr Author Take a look at these. Great price as well. http://www.diymobileaudio.com/forum/viewtopic.php?t=288KaliEdit: Sorry just realized you went with the Extremis. Enjoy!<{POST_SNAPBACK}>yah just saw those the other day. thanx for the attempt though kali, but no need to worry, that forum is like my 2nd/3rd stop when i go online.i would have gone with one of the better priced seas offerings but i figured i would try out the extremis, which adire claims to hang with the excels, revelators, etc.
July 8, 200521 yr Take a look at these. Great price as well. http://www.diymobileaudio.com/forum/viewtopic.php?t=288KaliEdit: Sorry just realized you went with the Extremis. Enjoy!<{POST_SNAPBACK}>yah just saw those the other day. thanx for the attempt though kali, but no need to worry, that forum is like my 2nd/3rd stop when i go online.i would have gone with one of the better priced seas offerings but i figured i would try out the extremis, which adire claims to hang with the excels, revelators, etc.<{POST_SNAPBACK}>Let me know how you like those extremis. I was looking at them as well before I decided to go with the excels for midrange and the L18RNX/P for midbass.Kali
July 8, 200521 yr Author will do. i think i'm gonna try em IB first and if i dont like that, i'm gonna build sealed doorpods for them.if you want other opinions, ask undercoverpunk. you can see em in his avatar above in this thread somewhere.
July 8, 200521 yr preliminary testing, with no where near enough power says...These things sound waaaaaayy, WAY bigger than they are, so far I like em...
July 9, 200521 yr Author i was wondering how many layers of glass did you put on your doorpods. i just started my doorpod glassing today but i'm gonna go sealed.
