Posted February 1, 201016 yr Hello,Today I pulled my Q12 from the box (Dual 2) and tested both voice coils.They seem to settle at about 1.4 to 1.5 ohm. Is this normal for a dual 2?*It has not seen power yet.
February 1, 201016 yr perfectly fine and in specD2 or 1 is the ''nominal'' load, which is all you need to worry about the reading on your dmm is ''DCR'' which is also in spec. no need for you to worry about that, stick with nominal
February 1, 201016 yr Indeed you are measuring Resistance and NOT Impedance so it is definitely expected to be in that range.
