no factory location in doors correct? how about kicks panels?
  • Replies 55
  • Views 5.8k
  • Randal Johnson
    Randal Johnson
    my 6.5" drivers with a very powerful amp does just as good as any 8" out there ... I run mine full range with no crossover ... mine are in the kick pannels (they staged better in the kicks instead of
  • Randal Johnson
    Randal Johnson
    Blues Car Audio tweets in the A pillars ... crossed at 3000 htz Blues Car Audio 6.5 " drivers in the kick pannels ... no crossover / fullrange Blues Car Audio Isoberic 10" transducers (pair) in a blow
  • Randal Johnson
    Randal Johnson
    I'm the guinipig for both sir ... and running ALOT of power ... My new 6.5" drivers have the same if not better lms specs than most 8"s on the market ...
What is your budget?
Do you have a picture of your door so we can see what it looks like so we can better guide you as to what you can make to go on it? Or what year S15 do you drive?
In the old days before fiberglass we made door panels out of just mdf that we screwed / bolted on to the door panel and recessed a speaker into them, but they were heavy as heck. Doing glass isn't too hard, you just have to take your time and get the right materials to make it come out nice, plus it's a lot less weight on the door. If you want to get a lot of good information about glassing, I would go to fiberglassforums.com and check out some of the builds on there. Those guys know their stuff when it comes to fabrication and I'm sure someone can steer you in the right direction. I know the basics of glass, but I'm still in AWE of what some of those guys can do.
The best advice I can give to you on components is go LISTEN to everything you can. Make your decision on what sounds best to YOUR ears. There are a lot of good speaker companies out there, I know which one I would use, but that's me. At the end of the day, what sounds best to YOU is what you should get. Good luck with your search for a component set, and be sure to post pics when you get them in.
  • 2 weeks later...
I actually just did this to my navigator, still working on it though.
The cdt 8's i got for like 60$ each and there rated at 200w
CDT Audio Subwoofers - Lowest Prices - Largest Selection - WoofersEtc.com
Also have the alpine type r's in the factory location.Most people fiberglass i'm just gonna cut and make fit, lol
Just need to fit the door panels really and i'll be done.
turn ur speakers down the highs are kinda loud.
the coaxials are alot cheaper than the components, but the type r coaxials are pretty nice for 50$ on amazon
The components are like 130$
