Posted February 9, 201016 yr Right now I'm running a icon 10 in a ported box to spec off of a aq1200d. I wanna try another set of subs and I have 2 si bm 10s laying around, my question is will those be louder, running off the aq1200d and a ported box, or will it pretty much sound the same as the icon? I was also thinking about a pair of sealed (no room for ported) 12s such as type-rs or ia 187s. Which route will be significantly louder?
February 10, 201016 yr Author I would wanna retain some sq but the main goal is to get louder. And the bms I have are the sundown rebuilds, which jacob stated that they can go ported from 1.2-1.5 at 30-35hz.
February 10, 201016 yr If you already have the si, try them in a good custom ported box.If you don't like them, you can sell them, keep the box, and find 10" subs that can fit in your box.Why not a second Icon 10" ? On 1200 watts, you will like them, for sure !Be careful with the box design, and build it right.Good luck
February 10, 201016 yr Admin If you already have the si, try them in a good custom ported box.If you don't like them, you can sell them, keep the box, and find 10" subs that can fit in your box.Why not a second Icon 10" ? On 1200 watts, you will like them, for sure !Be careful with the box design, and build it right.Good luck :drink40:
March 2, 201016 yr Author How would a single DC 4xl 10 with 2 aq 1200ds compare to the icon in the same box(1.5cu in, 32hz)? Big difference in output or a waste of time?
March 2, 201016 yr I would advise reading through this before posting again ..... Attention NOOBS!!!! - SSA Car Audio Forum 2 10" drivers vs 1 10" will be louder (Cone Area, Motor Strength)1 10" driver designed for SPL on twice the power vs 1 10" driver designed for SQ on same power.......Waste of time imo! 2 different designs and purposes for the drivers.
March 3, 201016 yr Author Ok I see what you're saying. I do wanna try for more spl which is why I was thinking about the dc 4xl 10. The idea was to just get a louder sub(4xl 10) and just drop it in the same box the icon was in, and power it with another aq1200d in the future. I am hesitant with going with a 2 10" setup since I dont really wanna go with a bigger box than I already have now because of space limitations.
