Posted February 10, 201016 yr i need to start a builtin log but 1st i need to know if this box will work am lookin for loudness/"""SQL""" and alot of good lo bass playin reggae and hiphop i found this site and was playin around with it an this is what i came up with (sub up port back) need to get advice before i start to built thanksbox width 34box hight 15both box depth 17wood .75square port width 3squaer port lenght 1: 13.5square port length 2: 8total port lenght 26.5tuned at 32 hzand about 3.306 cube RE Enclosure Calculator Edited February 10, 201016 yr by mr.tigger
February 10, 201016 yr I wouldn't use that calculator, it's way off if your port has a bent like yours does.
February 10, 201016 yr i need to start a builtin log but 1st i need to know if this box will work am lookin for loudness/""SQL"" and alot of good lo bass playin reggae and hiphop i found this site and was playin around with it an this is what i came up with (sub up port back) need to get advice before i start to built thanksbox width 34box hight 15both box depth 17wood .75square port width 3squaer port lenght 1: 13.5square port length 2: 8total port lenght 26.5tuned at 32 hzand about 3.306 cube RE Enclosure CalculatorNo such thing as SQL
February 10, 201016 yr One of the enclosure builders can do one for you, or use this to design your own.
February 10, 201016 yr You can also look at the SSA Technical section and check out the box designs that they have posted to see if they will work for you.
February 10, 201016 yr Author You can also look at the SSA Technical section and check out the box designs that they have posted to see if they will work for you.Hey i dont know if i went to the right place but i cant fine any with sub up port back an thats wat i was lookin for
February 10, 201016 yr Author You can also look at the SSA Technical section and check out the box designs that they have posted to see if they will work for you.Hey i dont know if i went to the right place but i cant fine any with sub up port back an thats wat i was lookin for want to do one built and finsh lol. i was lookin at the 15" ICON Small Ported Enclosure will this box work well for loudness? in a 95 grand cherokee jeep but want the sub on the top port back. if i put the sub on the top on the left hand side will it still work the same way??
February 16, 201016 yr Author ok i went with 3.5ft3 @35 hz i start last night and here it look like up to nowMobile PhotobucketMobile PhotobucketMobile PhotobucketMobile Photobucketim goin to cut out the hole for the sub 1st before i put on the top. tell me wat u guys think
February 17, 201016 yr id recommend using 45's for bracing but looks good so far. how much power are you running to it? might want to double baffle.
February 17, 201016 yr Author id recommend using 45's for bracing but looks good so far. how much power are you running to it? might want to double baffle.it will be playin off a 2000mb quart an yes the top is bouble flush mountMobile PhotobucketMobile Photobucketi like how Thumpper from pound that sound did his port so i was just tryin something Mobile Photobucket
February 18, 201016 yr Author well almost finish just wat to put a sundown decal/sticker on the front an need some 8 gauge speaker wireMobile Photobucketthe out side ring is a little bigger than the sub so u can see alittle green ringMobile Photobucketshowinh off the sub a little Mobile Photobucket wat u guys think my 1st real sub
February 18, 201016 yr Author How does it sound?haven put in yet cause i need to run new power wire an install an an its too cold an snow-ie out side to work but hope to do some work this week end
February 19, 201016 yr Author thanks for the comments cant wait to here how it sound in my jeep the nex step to finish the box is puttin a sundown sticker on the front of the box like this http://m791.photobucket.com/albumview/albums/tigger4834/1266541101.jpg.html?pbauth=1_uLEBonVPfaLdh1h3YMYz2Q%2BwGEHd5BHNGK4RsUEshiZOBYFDlNs1mRFYxXfs%2B9%2FtGO%2B%2B3qZdVsi2rlRTFQivYwiXXtuHwuH89wWfx7H7yyqMP9dwXLLM06%2FJQVFl8JNVNb6G05t%2F9Uc2bXPFl%2F8e6fNdDJrHQn1%2BvwZuE6KqFbU%3D that Derrick ( [email protected] ) is custom do for me Edited February 19, 201016 yr by mr.tigger
March 17, 201016 yr Author all this time i just finish the box an got it install with the yellow top in the back sound good shake the hold jeep an my rear view fall off lol but my truck reall need some dampin cause its loude inside but outside u hare alot of noise from the body of the truckMobile PhotobucketMobile Photobucket
