Posted February 11, 201015 yr we installed my single din headunit yesterday and im getting the movie playing through the speakers but not the actual video showing,could we have just missed a connection in the back?thanks for any information...
February 11, 201015 yr need lil more info what car?what kind of HU?what are you trying to do?what other components ?
February 11, 201015 yr Sounds like one of the wires is not hooked up, I forget but one wire will cause no image on screen when driving if you dont ground it off.
February 11, 201015 yr Author Sounds like one of the wires is not hooked up, I forget but one wire will cause no image on screen when driving if you dont ground it off.it doesnt show it even when in park.it shows that screen that says in order to view this dvd emergency brake has to be in but still plays through the speakers..
February 11, 201015 yr It will play through the speakers because that just like listening to music. Its watching that you cant do when driving. You need to ground the wire that is for the emergency brake and you shouldnt have that problem.
February 11, 201015 yr Although grounding that wire is technically against the law and you can be ticketed for it. PS I don't want to be a Debbie downer, just wanted to throw that info out.
February 11, 201015 yr Although grounding that wire is technically against the law and you can be ticketed for it. PS I don't want to be a Debbie downer, just wanted to throw that info out.yeah and you can also add a switch to make it work whenever you want it or not make it legal on command
February 11, 201015 yr Author It will play through the speakers because that just like listening to music. Its watching that you cant do when driving. You need to ground the wire that is for the emergency brake and you shouldnt have that problem.shouldnt it play in park is doesnt even do that
February 11, 201015 yr Author Although grounding that wire is technically against the law and you can be ticketed for it. PS I don't want to be a Debbie downer, just wanted to throw that info out.yeah and you can also add a switch to make it work whenever you want it or not make it legal on command its not playing even in park
February 11, 201015 yr Although grounding that wire is technically against the law and you can be ticketed for it. PS I don't want to be a Debbie downer, just wanted to throw that info out.yeah and you can also add a switch to make it work whenever you want it or not make it legal on command That's a great idea, thought never even crossed my mind.
February 11, 201015 yr Although grounding that wire is technically against the law and you can be ticketed for it. PS I don't want to be a Debbie downer, just wanted to throw that info out.yeah and you can also add a switch to make it work whenever you want it or not make it legal on command That's a great idea, thought never even crossed my mind.yeah i did the same thing for my radar detector just in case i ever get an a-hole cop, i can just turn it off
February 11, 201015 yr Author what brand and model number is it?it may help me figure it out a lil betterDual XDVD8181
February 11, 201015 yr did you hook up the reverse wire?i know you prob dont have a camera hooked up , put im not 100% sure put you may have to have the reverse wire hooked up other then that the only thing i can suggest is to make sure your (yellow/blue) parking wire is hooked up correctly Edited February 11, 201015 yr by ivan95m
February 12, 201015 yr have you tried to do this?There are usually two situations that start the PARKING BRAKE Sequence.First situation is while driving:1) Stop vehicle, put in Park, make sure PARKING BRAKE is off / released2) Depress PARKING BRAKE for 1 sec3) Release PARKING BRAKE for 1 sec4) Depress PARKING BRAKE permanentlyNOTE: Once above procedure 1-4 is completed, approx 3sec—video will display.Second situation is while already parked and the PARKING BRAKE is alreadydepressed:1) Keep vehicle in Park, PARKING BRAKE should be off2) Release PARKING BRAKE for 1 sec3) Depress PARKING BRAKE for 1 sec4) Release PARKING BRAKE for 1 sec5) Depress PARKING BRAKE permanentlyNOTE: Once 2nd procedure is completed, approx 5 sec—video will display.NOTE: This procedure will have to repeated if the IGN is turned off.
