Posted July 8, 200521 yr Well I'm writing this for anyone who might care. I'll go through the steps of how to take apart a speaker(with pics of course).Here are the supplies. 1 Koda6 (thank you Nick), 1 bottle of CA unbonding glue, and a utility knifeFirst, run the knife around the edge of the surround to separate it from the basket. The Koda has a stretchy rubber surround so it didnt really cut so well.Then, just cut the speaker leads.And detach the spider from the basket. This was the tricky part. I found that although being soaked in the CA unbonding glue for a few minutes, it just woundn't budge. So i just took the knife to that as well. It was quite flimsy and easy to cut.And now you've got yourself a large magnet and a lovely little hat.
July 8, 200520 yr not bad.now drill out the rivs holding the basket to the motor. <{POST_SNAPBACK}>The SX was dissambeled as far as you could possibly go.Dust cap off, basket and motor apart, coil un wound.
July 8, 200520 yr That gives me faith ... tomorrow, I will do my best at gently picking apart a stock speaker.
July 8, 200520 yr acid,can you now show me how to put it back together , with pis , and a small vidio of it playing!
July 8, 200520 yr Author acid,can you now show me how to put it back together , with pis , and a small vidio of it playing!uhhh... i have vids of it "playing" but its not going back together
July 9, 200520 yr Author Why didn't you use it?i tried, i soaked it and let it sit for like 10 minutes and nothing happened, so im like screw this and cut it
July 9, 200520 yr Yeha, now try that with a TOTTIE JOHSON apporved MT. Lol...Quad Triple Stiff spiders, MASS specially formulated CA Glue...it's redic. NG
July 10, 200520 yr * busts out the blow torch*<{POST_SNAPBACK}>*busts out the oxy acetalien (sp) torch**doesnt work**plasma cutter**basket go bye bye*
July 11, 200520 yr Yeha, now try that with a TOTTIE JOHSON apporved MT. Lol...Quad Triple Stiff spiders, MASS specially formulated CA Glue...it's redic. NGGet ya a REALLY strong arm and one hella sharp paper knifecomes right apart
