Posted July 8, 200521 yr this is really wierd. ummafter i hooked up my friends speakers. when it was at my house, there was no noise at all.but now my friend calls me when he gets home, and he hears this high pitch whistling noise comin from the speakers, but its only at low volumes. When he turns the volume high, the noise goes away and everything is fine.I'm guessing a ground problem, but there is no noise from the subs and why did it appear when my friend get home?
July 8, 200521 yr Or loose wire(s) that moved when the vehicle was in motion. Is it whine while the vehicle is running or does it do it while off as well?
July 8, 200521 yr Author Or loose wire(s) that moved when the vehicle was in motion. Is it whine while the vehicle is running or does it do it while off as well?<{POST_SNAPBACK}>its when the car is running. when the car is off, it sounds fine. whats up with the loose wires? elaborate please?
July 8, 200521 yr Yes, wires that may have come loose after installation when the vehicle has been subjected to motion. Also, as for the ground, I make it a POINT to NEVER use a factory ground wire. Always make a dedicated GOOD ground. The factory point is often weak or looped throughout other grounds.
July 8, 200521 yr Author Yes, wires that may have come loose after installation when the vehicle has been subjected to motion. Also, as for the ground, I make it a POINT to NEVER use a factory ground wire. Always make a dedicated GOOD ground. The factory point is often weak or looped throughout other grounds.<{POST_SNAPBACK}>umm your talking bout the amp to the chassis wire rite?and for the speakers, disconnected as in at the amp, or speaker?
July 8, 200521 yr Author HU ground. As for the wiring, could be anywhere. Gonna have to troubleshoot.<{POST_SNAPBACK}>ah i see. its not the HU ground cuz my friends had the same hu for a few months now with no problems.great... i gota look thru the system again... it will only be at the connections rite Tire?sorry for all the q's
July 8, 200521 yr Author okeee i don see him again until sunday. ill get back to you then thanks man!
July 8, 200521 yr Here is what to do:If they are amp powered:Disconnect the RCA's from the amp... Noise still there? It is the amp ground that needs to be fixed, or a speaker wire is bad..If the noise disappears, then you need to fix the HU ground, or have bad RCA's. If the speakers are deck powered, then only a cpl things could be wrong, speaker cables, or HU ground.
July 8, 200521 yr Author Here is what to do:If they are amp powered:Disconnect the RCA's from the amp... Noise still there? It is the amp ground that needs to be fixed, or a speaker wire is bad..If the noise disappears, then you need to fix the HU ground, or have bad RCA's. If the speakers are deck powered, then only a cpl things could be wrong, speaker cables, or HU ground.<{POST_SNAPBACK}>if i disconnect the rca's there wont be any music playing.. oh i getit. it will just be the noise with no music.wow you are so helpful today scott! (err that is your name rite?)
