Posted February 26, 201015 yr So what size speaker wire should I use to go from my sub to sub box? Also what size should I use to go from my sub box to amp. I am getting a 12" Lethal Injection and a Sundown Audio SAE-1200D. Thanks in advance.Jeremy
February 26, 201015 yr So what size speaker wire should I use to go from my sub to sub box? Also what size should I use to go from my sub box to amp. I am getting a 12" Lethal Injection and a Sundown Audio SAE-1200D. Thanks in advance.JeremyNext time use the search feature my friend, plenty of topics on this already. You can use the same size in box and outside of box, 10 gauge or smaller will be fine.
February 26, 201015 yr Author Sorry about that. I should have checked. Wasnt thinking. Thanks for the help though.Jeremy
February 27, 201015 yr I use 12 gauge with no issues Remember you have 100+ feet of 18 gauge in the coil.
February 28, 201015 yr Author If I am going to go with 4 gauge wire what should I fuse it at? Max of the wire or a little more than the amp handles? I'm going to have a sae 1200d/. Any help would be appreciated.
