Posted March 2, 201016 yr It was between posting on here or in home audio but i just decided to post here.... my older brother has a Sony WM500 subwoofer that he bought a couple years back and does not use it so I decided to start a fun, little, "screw around" project. I have already taken the powered amp off the original enclosure and disconnected all the wires. Also I have taken out the actual subwoofer and taken out the power on button from the sub and I am planning on building a box for this sub.First off here is the subwoofer w/ powered amp: http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11027875Ok, so the box can be as small or as big as needed because it is going to be in my room and shape does not matter. For this build I am just looking to get as loud as possible without sounding like absolute a$$. I don't really have any ideas so far so just throw out any ideas or what you think would work best.p.s. - first box build for me so nothing "too" crazy. thanks guys,alex
March 3, 201016 yr Admin You can use the Sony enclosure as a starting point and see how it maps out. Then start considering larger sizes.
March 3, 201016 yr Author You can use the Sony enclosure as a starting point and see how it maps out. Then start considering larger sizes.thats sort of what I had planned... I was going to measure it and see how big it was and increase it by atleast .5 cu ft plus bigger port. Just basically mess around till im satisfied. I was just wondering if someone had some better ideas before I got started.
March 3, 201016 yr Author one other question, 99% of the installs ive seen use MDF wood. For a home install (Since i guess weight is less of an issue) is there a better choice or should I just go pickup some MDf from Home Depot, Lowes, etc
