July 12, 200520 yr Author Rarely need to, but if you do, use weatherstripping.<{POST_SNAPBACK}>As in the foam strips with adhesive tape on one side?
July 12, 200520 yr I use the high density stuff. Get the stuff that looks more like rubber. It's made for tight seals.
July 12, 200520 yr http://www.partsexpress.com/pe/showdetl.cf...tnumber=260-540http://www.partsexpress.com/pe/showdetl.cf...tnumber=260-542http://www.partsexpress.com/pe/showdetl.cf...tnumber=269-300
July 12, 200520 yr Admin side note: some of the competitors have been using duck tape recently to hold some leaks in
July 12, 200520 yr When i had my funky pup in my friends enclosure i used electrical tape.There was no way foam would stop the leaks, the frame was bent really nice
