Posted March 7, 201016 yr I have a 2001 Blazer 4 door 4.3L 2WD and i think my alternator is bad. The things i have nticed are when i have the car at idle and i give it gas to about 3000RPM and let it go, the volts according to the gauge cluster go from 14.16 down to 13 volts and then it jumps back to 14.13-16 on idle. Another thing that i have noticed is i have a 1000watt RMS car audio systm and when i have my music up decently loud. My sub cuts out until i lower the volume a bit. The battery i have unde the hood is a brand new optima yellow top. The one with the light grey casing. I also have the big 3 upgrade using 1/0 tsunami oxygen free compotion power wire. My grounds on my amps are good. Full contact to metal. I sanded down the paint where i have them bolted to. What do you guys think i should do?? I belive the stock alternator is 100 amps. I was thinking to jumping to a 120 amp alternator or problobly even a 140 amp alternator. Input would be great. THNX
