Posted July 15, 200520 yr the 4 ft will be below the windows, and the 6 will be above the windows.the 6 can be plugged to ~7ft @ ~32-34Hz w/ ~ 75^2 port. the other one i haven't sat down to figure it out yet...i think i wanna go under the window if i do decide to compete, cause i don't know how well i'd do in the higer class what you guys think?
July 16, 200520 yr try both see what your numbers are for the under the win and if you like it stick wt it, if not try something else
July 16, 200520 yr Author Not good...NG<{POST_SNAPBACK}>not good what? i had the RL-p's in a box that was 4.5ft^3 under the window, @ 37Hz w/ 68in^2 port and did a 151db on the old TL. and this one would be tuned higher and have more port.
July 18, 200520 yr Author Not good...NG<{POST_SNAPBACK}>not good what? i had the RL-p's in a box that was 4.5ft^3 under the window, @ 37Hz w/ 68in^2 port and did a 151db on the old TL. and this one would be tuned higher and have more port.<{POST_SNAPBACK}>?????anyone else have an opinion???
July 18, 200520 yr if your going over the window line may as well wall it so 4cuft, if results are undesirable try the other enclosure...MDF is like 20 bucks a sheet screw maybe 10bucks for 2 lbs and a $7 thing of wood glue... so if you use 2 sheets thats $57 unless you think you have to make it purdy the window line is what will keep me from compeating any further than local with my current enclosure. but me thinks in a year + senior project...hmmmmm wall or S-2??
July 18, 200520 yr Author if your going over the window line may as well wall it so 4cuft, if results are undesirable try the other enclosure...MDF is like 20 bucks a sheet screw maybe 10bucks for 2 lbs and a $7 thing of wood glue... so if you use 2 sheets thats $57 unless you think you have to make it purdy the window line is what will keep me from compeating
July 18, 200520 yr Depending on what organization you compete with, they don't all have window line rules.
July 18, 200520 yr Author Depending on what organization you compete with, they don't all have window line rules.<{POST_SNAPBACK}>what are the diff organizations? and do you got any links to an event calander for the diff orgs.? i'm really open to any of them, i just want something where i can go to more than 1-2 comps a year w/o driving 5-6 hours and no i don't know the res freq. i'm just basing the tuning on 40 shouldn't be too high for daily driving, and 40 will, more than likely, peak higher than my 35 box.
July 19, 200520 yr Author MECA i know has window regs, i dont know about dB drag or ISCA or w/e it is.<{POST_SNAPBACK}>the dbdrag rule says that any equiptment above the window line is considered to be a wall...but that db drag i went to a couple weeks ago i was classed SS 1-2 NW , huh?
July 20, 200520 yr Correct, a "NW" no wall class. You can have lots more equipment, just no wall. I'm guessing STL is St Louis?? So here are some shows.Db DragJuly 23rd Moberly, MOJuly 24th Springfield, MO (2X)August 13th Moberly, MOMecaJuly 23rd Bolivar, MOJuly 23rd McHenry, ILIASCAJuly 23rd Galesburg, IL
July 20, 200520 yr Author Correct, a "NW" no wall class. You can have lots more equipment, just no wall. I'm guessing STL is St Louis?? So here are some shows.Db DragJuly 23rd Moberly, MOJuly 24th Springfield, MO (2X)August 13th Moberly, MOMecaJuly 23rd Bolivar, MOJuly 23rd McHenry, ILIASCAJuly 23rd Galesburg, IL<{POST_SNAPBACK}>you know the closest of those comps are about 3 hours away, the ones in il are a good 6-7 hr drive you forgot one thoughIASCAjuly 24th Granite City, IL @ NOPI 25min away
July 21, 200520 yr Author because i'm not besides i don't know if id trust my car on trips over prob. 2 hrs away...
