Posted March 16, 201016 yr I've been trying to figure out some theoretical expectations from a few subs using Winisd. I want to use a sealed enclosure, but I can't figure anything out with the SSD (12 inch Dual 2 ohm) until I know the higher qts. Does anyone know what it is? Hopefully I'm not being dumb and just can't find it. I know the Qts is figure by using the Qes and Qms numbers, so which ever changed would be helpful too.
March 17, 201016 yr If you want to use a sealed box with the new SSD 12 then choose the high qts model and follow the box guidelines in the tech section...Right off the top of my head..I don't know what it is.
October 18, 201015 yr If you want to use a sealed box with the new SSD 12 then choose the high qts model and follow the box guidelines in the tech section...Right off the top of my head..I don't know what it is.this might be also a dumb question. but is the high qts option able to be used in a ported box? or is this a no no? like the guy previous said there reall isn't any info on this. thx
October 18, 201015 yr If you want to use a sealed box with the new SSD 12 then choose the high qts model and follow the box guidelines in the tech section...Right off the top of my head..I don't know what it is.this might be also a dumb question. but is the high qts option able to be used in a ported box? or is this a no no? like the guy previous said there reall isn't any info on this. thxIt's a no-no.If you want to use a ported enclosure, use the normal driver.Don't put the High Qts driver in a ported enclosure.
October 18, 201015 yr If you want to use a sealed box with the new SSD 12 then choose the high qts model and follow the box guidelines in the tech section...Right off the top of my head..I don't know what it is.this might be also a dumb question. but is the high qts option able to be used in a ported box? or is this a no no? like the guy previous said there reall isn't any info on this. thxWhat Is High Qts
October 18, 201015 yr If you want to use a sealed box with the new SSD 12 then choose the high qts model and follow the box guidelines in the tech section...Right off the top of my head..I don't know what it is.this might be also a dumb question. but is the high qts option able to be used in a ported box? or is this a no no? like the guy previous said there reall isn't any info on this. thxIt's a no-no.If you want to use a ported enclosure, use the normal driver.Don't put the High Qts driver in a ported enclosure.Speak of the devil.
October 19, 201015 yr Standard driver can be used ported or sealed. High Qts is better for sealed only applications.
