June 28, 201115 yr 7k2e 250a alt, 5 batts, multiple 1/0 runs.welllllllll, the story kinda goes like this...boom boom boom ..amp cuts off , reset it HU, boom boom boom , amp cuts off again sniff sniff sniff, somins burnin is it the subs? ppl are feeling the subs like hmm kinda warm not really hot though.chop is like the only one like hmm check the amp, its still flashing the low voltage led code I THINK couldn't make out the code because of panic almost lol, he's like yup shes smoking.Cut the car off..chop goes to pull the amp out and big flash and poof, fire inside the amp now amp is pretty much roasting hotdogs like a grill as we try to disconnect it, sprayed it wt my extinguisher and the pics above are the final outcome.Mind you it wasn't even turned up full tilt, the clipping light was not flashing either.Matter of fact i had it louder on the way down there while i was driving.while driving i could keep it up above 13v easilynow at Tru i only had it on and idling, but catching on fire is rediculous especially if specs say it was from 10-15v.another note it would cut off at 14.8v and higher, but on the stetsom section i never got an answer about that either.--Both 300A fuses were not popped either
July 1, 201115 yr update:amps still under warranty!!Seems this is its last month yay methis is awesome....good luck for a good guy!
July 1, 201115 yr anybody coming out to the strip tonight, we plan on hanging at tru for the first few hours....until the tow trucks come agian! lol
July 3, 201115 yr lil david's dakota.....proud of ya nephew...340w per and you are slamming...keep up the progress!
July 3, 201115 yr played with a 4th order today w/ a rf p3 15" it did not do anything worth noting on the lows....once the music hugged mid 40's/ upper 50's....it really did seem impressive for low wattage(no meter)
July 3, 201115 yr was baby sitting a old re w/fresh ab recone...went to move it, motor went toward my feet as basket flew toward my face!glued failed like that?wow, this sucks....gotta see if repaire is an option, havent seen this before
July 3, 201115 yr was baby sitting a old re w/fresh ab recone...went to move it, motor went toward my feet as basket flew toward my face!glued failed like that?wow, this sucks....gotta see if repaire is an option, havent seen this beforeOuch, that's a tough fix. Looks like the magnet came unglued form the top plate? A high strength epoxy is needed, the hard part though is aligning it correctly.I'd consider it a manufacturer defect, try to get a hold of them.
July 8, 201115 yr 82$+tax superstart-group 31 (semi truck) batterysare these a good car audio approach, interested in a couple...how long this price?
July 12, 201115 yr and you got that price for a while , right?should we plan on coming up there for them or can you roll over to tru?
