Posted March 19, 201016 yr when bridging a 2 channel amp do i need to have y adapters @ the hu as well as the amp inputs or do i just wire the rca's as normal? thanks in advance
March 19, 201016 yr Author the reason i brought this up is because i have this old ass alphsonik(us acoustics) amp and the instructions were saying to use a y adapter and run the signal to a mono source..this amp will be powering a dual 12 4 ohm bandpass box Edited March 19, 201016 yr by nickeveready
March 20, 201015 yr Author 4 channel amp?2 channel stable down to 2 ohms Edited March 20, 201015 yr by nickeveready
March 20, 201015 yr You cant bridge a 2channel amp to 2 ohms, most amps that I know of can only be bridged to 4 ohms.
March 20, 201015 yr You cant bridge a 2channel amp to 4 ohms, most amps that I know of can only be bridged to 4 ohms.I would agree with this. 4 ohm if you bridge.
March 20, 201015 yr Jay-cee you both contradicted yourself. Most amplifiers cannot be bridged to 2 ohms, they will go into protect, stick with 4 ohms. Think of it this way, what happens when you combine two different 2 ohm channels into one channel, you get one 4 ohms channel. Now apply that to a 2 ohm final load, a class A/B amplifier will not work with 1 ohm on each channel.
March 20, 201015 yr Jay-cee you both contradicted yourself. Most amplifiers cannot be bridged to 2 ohms, they will go into protect, stick with 4 ohms. Think of it this way, what happens when you combine two different 2 ohm channels into one channel, you get one 4 ohms channel. Now apply that to a 2 ohm final load, a class A/B amplifier will not work with 1 ohm on each channel.Thanks and Fixed, definitely didnt proof read at all. .
March 20, 201015 yr That old of an amplifier from Alphasonik will be able to be ran bridged but only at 4 ohms and please follow the directions of the manufacturer.
March 21, 201015 yr Author thanks for the replies and yes the amp will be ran in 4 ohm, so i'll just follow the manufactures instructions and use the y-cables i guess
March 21, 201015 yr Jay-cee you both contradicted yourself. Most amplifiers cannot be bridged to 2 ohms, they will go into protect, stick with 4 ohms. Think of it this way, what happens when you combine two different 2 ohm channels into one channel, you get one 4 ohms channel. Now apply that to a 2 ohm final load, a class A/B amplifier will not work with 1 ohm on each channel.Mine Will But that is a good rule of thumb. There is only a handful of multi a/b channel channel amps that will run 1 ohm stereo/2 ohm bridged.
March 21, 201015 yr Jay-cee you both contradicted yourself. Most amplifiers cannot be bridged to 2 ohms, they will go into protect, stick with 4 ohms. Think of it this way, what happens when you combine two different 2 ohm channels into one channel, you get one 4 ohms channel. Now apply that to a 2 ohm final load, a class A/B amplifier will not work with 1 ohm on each channel.Mine Will But that is a good rule of thumb. There is only a handful of multi a/b channel channel amps that will run 1 ohm stereo/2 ohm bridged.Yes there are freaks out there Turd, but they are few and far between.
