how much power does an 18 mayhem handle in the max 8 cft enclosure for daily bumping?
i have two 2610s which i could link to 5,2 kw. BUT with voltage drop to 12,8 there will just be around 3,3 kw.
Brian had his running on about 4400rms at .05 ohm and had no problems. I personally am going to put a little more on mine with the same ohm load, maybe around 4600-4800. What kind of electrical do you have, type of vehicle????? INHO If your only using it for daily bumping, one 2610 is MORE than enough and will cause less strain on your vehicle andgive your sub a longer life. If you dont believe me, looke at the vid with the 2 Mayhems. They are flexing the crap out of the Suburban on only 1 AQ2200d.
If you are going to run more ~2500 watts to a single 18", I would shoot for 6-6.5 cuft, not
8. Your mechanical power handling is going to drop in 8 cuft. . .
