Posted March 24, 201015 yr I have 2 Fi ssd 12's that gave up on me finally. I was wondering what would be the best way to get them reconed? I have a Memphit The Mojo MC200D Amp it is 2000X1 at 2 ohm rms. Would I want to get the dual 2ohm or the dual 1ohm to run to this amp?
March 25, 201015 yr Author You want them to be D2 ohms so you can get a 2 ohm final load:I would not want to get the dual one ohm and wire them down to 2 ohm each and run them respectivley to the - + - + on th amp. the amp is wierd to me it says it does 2000 rms at 2 ohm x1 but i don't see why there would be 4 spots to put speaker wire.
March 25, 201015 yr If you get dual 1 ohm speakers and wire both of them to two ohms at put them on the amp like that then the amp will drop the ohm load down to 1 ohms and you will mess your amp up more than likely.It is 2000w x 1 @ 2 ohms, the reason for the extra speaker terminal is for simplicity of wiring among other things. It is still a one channel amp, just has two sets of terminals for the speaker wire to go.You could get the Dual 2 ohm subwoofers and instead of wiring them together then you can wire them individually in series to see a 4 ohm load. Send each speaker wire to its own set of terminals and the amp itself will drop them down to 2 ohms for you:
