April 6, 201016 yr Looking good. That's gonna be loud. My buddie has 2 component sets in his single cab dakota and I go deaf. Can't wait to see this all done.
April 7, 201016 yr BanginGMC where at in Arizona do you live? If I still had family out in Mesa I would probably have made a trip out there this summer haha
April 7, 201016 yr Author more pics dude ...lets see this new shipment......... Should be coming in this week or early next week Looking good. That's gonna be loud. My buddie has 2 component sets in his single cab dakota and I go deaf. Can't wait to see this all done.Yeah, i hope it gets loud.BanginGMC where at in Arizona do you live? If I still had family out in Mesa I would probably have made a trip out there this summer hahaI live in Glendale. Mesa is pretty nice, but.. if you aren't use to the weather here.. god DAMN is it hot!
April 8, 201016 yr Author Wheres all the progress pictures?keep up the good work Brother.My hands are tied until i get the equipment Buuuut im pretty geeked!
April 8, 201016 yr Author (2) SPR-17S 6-1/2" Component 2-Way Speaker (1) Alpine PDX 4.100(1) 4 Gauge Amp Kit from Knukonceptzis on its way!
April 8, 201016 yr the no equipmet thing is always a set back. Hurry up and wait.I shall be tuned in any who's.
April 8, 201016 yr I just removed my SPR-17S's today, I have had them for over a year. They will sound P-u-u-r-r-r-fect on 100 watts each. You will like them, Where are you mounting the tweeters?
April 8, 201016 yr Author the no equipmet thing is always a set back. Hurry up and wait.I shall be tuned in any who's.hahaha i will do just that.I just removed my SPR-17S's today, I have had them for over a year. They will sound P-u-u-r-r-r-fect on 100 watts each. You will like them, Where are you mounting the tweeters?I was thinking in the doors next to the 6.5s but then it might sound muffled from being so low, so i'm thinking my A pillars
April 8, 201016 yr I had the tweeters in the a-pillars for about 6 months, they would work BEST up there if you can get them on axis. Otherwise I recommend high in the doors.I only say this because at extremly high volumes they get lost off axis.
April 8, 201016 yr Author I had the tweeters in the a-pillars for about 6 months, they would work BEST up there if you can get them on axis. Otherwise I recommend high in the doors.I only say this because at extremly high volumes they get lost off axis. Then the doors it is! i'm thinking the arm rest part, as far forward as i can go. Thank you for the heads up
April 8, 201016 yr Author Found this on Craigslist for 70.00 bucks, but i got it for 40.00 boo yah! Would it be worth having it in the install with my PDX 4.100? hmmm...Shes a little dirtyWith some scratches
April 9, 201016 yr Sweet score! are you going to mount it somewhere you can see it? That would be cool. As far as your adding a second batt for your highs, you will want the second batt as close to the amp as possible, like 18" or less. Any time you add a battery you are making your alternator work harder, SO make sure to watch your voltage when you first hook it up. IF this is a frame and body vehichle you will want to ground the second batt to the floor and ALSO put a short wire under the body hooked to the same bolt and the frame. SO sandwich the body with the ground bolt, make sense? Your big3 should ALSO include a forth wire grounded to the frame from the engine block/alternator mount.Keep up the good work.
April 9, 201016 yr Author Sweet score! are you going to mount it somewhere you can see it? That would be cool. As far as your adding a second batt for your highs, you will want the second batt as close to the amp as possible, like 18" or less. Any time you add a battery you are making your alternator work harder, SO make sure to watch your voltage when you first hook it up. IF this is a frame and body vehichle you will want to ground the second batt to the floor and ALSO put a short wire under the body hooked to the same bolt and the frame. SO sandwich the body with the ground bolt, make sense? Your big3 should ALSO include a forth wire grounded to the frame from the engine block/alternator mount.Keep up the good work.I am planning on working it into my amp rack somehow, for the time being i have the whole ext cab to work out a amp rack, so space shouldn't be an issue.I am going to ge getting a Stinger Volt Meter one of these days, i have the spot to mount it as well. Thank you for the tips on grounding!
April 9, 201016 yr You can NEVER have to many grounds.As far as voltage meter if you like having one glaring at you at all times the Stinger one is cool, of wise I just have on I stick in the cig lighter when I want to check my voltage.Do work Son.
April 9, 201016 yr Author Items Shipped:(2) SPR-17S 6-½ Type-R Component SpeakersEstimated delivery Apr 14, 2010Item name: NEW ALPINE PDX-4.100 400 WATT 4/2 CHANNEL AMP AMPLIFIERYour package is on time with a scheduled delivery date of 04/12/2010. Product NameKOL-AK44 Complete 4 Gauge 4 Channel Amplifier Installation Kit Scheduled Delivery: 14-April-2010 Edited April 9, 201016 yr by BanginGMC
April 9, 201016 yr Author You can NEVER have to many grounds.As far as voltage meter if you like having one glaring at you at all times the Stinger one is cool, of wise I just have on I stick in the cig lighter when I want to check my voltage.Do work Son.Yeah, i want it so it's always tellin' me whats good. I have to go with blue to match my PDX amp There is a new branch of PDX amps out and GOD DAMN do they look sexy!!!!!! Edited April 9, 201016 yr by BanginGMC
April 9, 201016 yr Author i got a little hc600 too, but dont know what to do with himPut the little guy next to your hc2400 haha spice things up a bit.
April 9, 201016 yr i got a little hc600 too, but dont know what to do with himPut the little guy next to your hc2400 haha spice things up a bit.that wouldn't be a bad idea
April 9, 201016 yr Author i got a little hc600 too, but dont know what to do with himPut the little guy next to your hc2400 haha spice things up a bit.that wouldn't be a bad idea Glad i could help
April 10, 201016 yr Author Puttin an order in at Sound Deadener Showdown for my doors today!Order Includes:16 CLD Tiles1 roll Extruded Butyl Rope1 sheet 1/4" CCF
April 10, 201016 yr Puttin an order in at Sound Deadener Showdown for my doors today!Order Includes:16 CLD Tiles1 roll Extruded Butyl Rope1 sheet 1/4" CCFThe Butyl Rope is 1 great product!
