Posted March 31, 201016 yr I don't fully understand Port Velocity. Using BBP I can figure the velocity but at what are the acceptable limits prior to encountering negative effects?
April 1, 201016 yr Depends on what you would subjectively define as negative effects.I have to ask, you design T-lines but don't understand port velocity??
April 1, 201016 yr Author Dude where have you ever read that I design t-lines to my recollection I have said I have a t-line designs for 2 sa-8. And that is about it. There aren't but a couple of people I disdain and it seems your one of them. Now if you would like to share some of your knowledge I'll gladly read it for what it's worth. I am pretty active in reading on this forum and it seems 90% of your remarks are prideful or haughty. Only a fool thinks he knows everything.
April 1, 201016 yr Here's what TermPak has to say about it:"When designing a vent, you should try to keep the vent air velocityvalue as low as possible. Otherwise, vent turbulence and otheraudible artifacts may be heard.Ideally, you would use a vent with a very large surface area tokeep the vent air velocity low. This would work because vent airvelocity is directly related to the area of the vent being used.Unfortunately, the larger the vent area, the longer the vent lengthneeds to be for a given tuning frequency. In reality, large area vents usually need to be so long that they’re just not practical.Because of this, many designers are forced to trade-off vent airvelocity for vent length.Typically, audiophiles recommend keeping the vent air velocitybelow 5% of the speed of sound. This is not very realistic inautosound installations where enclosure volumes are usuallypretty small. At Wayne Harris Enterprises, we have determinedthat a vent air velocity as high as 12% is acceptable for mostinstallations. With an Aeroport, the vent air velocity can be as highas 20% without running into significant problems."I hope this may help to explain it.
April 1, 201016 yr Here's what TermPak has to say about it:"When designing a vent, you should try to keep the vent air velocityvalue as low as possible. Otherwise, vent turbulence and otheraudible artifacts may be heard.Ideally, you would use a vent with a very large surface area tokeep the vent air velocity low. This would work because vent airvelocity is directly related to the area of the vent being used.Unfortunately, the larger the vent area, the longer the vent lengthneeds to be for a given tuning frequency. In reality, large area vents usually need to be so long that they’re just not practical.Because of this, many designers are forced to trade-off vent airvelocity for vent length.Typically, audiophiles recommend keeping the vent air velocitybelow 5% of the speed of sound. This is not very realistic inautosound installations where enclosure volumes are usuallypretty small. At Wayne Harris Enterprises, we have determinedthat a vent air velocity as high as 12% is acceptable for mostinstallations. With an Aeroport, the vent air velocity can be as highas 20% without running into significant problems."I hope this may help to explain it.a good bit of information here!!! +1 for the find.
April 1, 201016 yr Dude where have you ever read that I design t-lines to my recollection I have said I have a t-line designs for 2 sa-8. And that is about it. There aren't but a couple of people I disdain and it seems your one of them. Now if you would like to share some of your knowledge I'll gladly read it for what it's worth. I am pretty active in reading on this forum and it seems 90% of your remarks are prideful or haughty. Only a fool thinks he knows everything.Unless my memory is off, which I don't think it is you were pushing them on chop.If you want my knowledge ask a good question, show that you tried, and stop being a baby about it. Amusing that you would bring up a definition of a fool considering I will always tell everyone I learn new stuff everyday, definitely never claimed that I already know everything. Not even close.You've been on here long enough to know what makes a good thread and what doesn't, you've also read the T&C's well enough to know that this surely didn't match the requirements. If you are lazy in your thread, you'll get lazy answers. If you put in energy, then the response might be what you are looking for. If your inadequacy in posting makes you disdain me perhaps a quick look in a mirror will enlighten you. If not, oh well, I guess we can't help then anyways.
April 1, 201016 yr I think in the beta version of winISD it wants you to keep it under 14 m/s, which is around 5% of the speed of sound. So a bit low perhaps. But I haven't tested various port designs and velocities to determine where a cutoff point might be. I'd say up to 10% or 30 m/s for a round number may be acceptable.
