Posted April 2, 201016 yr hey guys i was wondering whats the best way to get the ca glue off the basket im using a chisel its worling but making a lot of nicks let me know guys thanks, billy
April 2, 201016 yr maybe dremel? (sp?) or sand paperdrill bit with wire bush attachmentsteel woollots of stuff out there that might work
April 2, 201016 yr yeah theres a few things id try before a hammer and chisel, i could see that doin some damage. i saw a guy do it with a drill and an abrasive pad like lithium suggested
April 4, 201016 yr turn the chisel upside down so the angled part rides along the surface of the basket. Then a sanding roll on a die grinder or dremel to clean it up...
April 4, 201016 yr As said above, a wire brush is the best for removing CA as well as preparing the surface for more glue.
