Posted April 2, 201015 yr Sorry for such a stupid question, but the owners manual isn't really specific about 1-ohm load with 2 subs.I have two infinity 100.9's (10" SVC, selectable 2 or ~4 -ohm impedence, obviously set to 2-ohm). I want to run a 1-ohm load on a SAZ 1000D.My question is, how do I wire them? Do I wire one to each set of speaker terminals and yield a 1-ohm load or will this yield 2-ohm? This is shown in the 2nd diagram on page 7 of sundown manual.... or ... Do I need to wire them in parallel as shown being done with only 1 sub in the top/1st diagram on page 7 of the sundown manual, a method of wiring that I've NEVER seen before on a mono amp?If this were an old-school HCCA amp, I'd know the answer... with Class D stuff and the sundown brand, I'm not so sure.Thanks for any help! Edited April 2, 201015 yr by southwow
April 2, 201015 yr Author I think I've answered my own question. The manual is probably describing individual speaker impedence rather than total impedence (hence the 2-ohm minimum). This would mean that the two 'channels' are really just wired in parallel internally, meaning that diagram #2 on page 7 of the manual is the correct way to wire 2 subs in parallel.
April 2, 201015 yr you could always go here and get specifics for your sub/load for a second "opinion".hope that helps
April 3, 201015 yr I think I've answered my own question. The manual is probably describing individual speaker impedence rather than total impedence (hence the 2-ohm minimum). This would mean that the two 'channels' are really just wired in parallel internally, meaning that diagram #2 on page 7 of the manual is the correct way to wire 2 subs in parallel.Yeah basically thats what it will do, so select the switch for 2 ohms on each subwoofer and wire each subwoofer to its own terminal. The amp will will drop the load to 1 ohm for you. Hope that helps
April 3, 201015 yr Yes just wire both speakers to the + and - terminals on the amp and make sure your impedance is selected to 2 ohm.
April 3, 201015 yr Author Yes just wire both speakers to the + and - terminals on the amp and make sure your impedance is selected to 2 ohm.Thanks for the help everyone!
April 30, 201015 yr I've never seen a sub before with a switch to go between two and four ohm. Are these common? Seems like a pretty novel idea.
