April 10, 201015 yr Author I should b able to pull it out tomorrow. Or today i should say, and take a pic and find out which one it is.
April 10, 201015 yr Author Ya I have pix of every other part of the woofer except the back haha. I wish I woda known that's where u can tell the difference
April 10, 201015 yr Ya I have pix of every other part of the woofer except the back haha. I wish I woda known that's where u can tell the differenceSomebody will be able to tell by the back of the motor.
April 10, 201015 yr Sometimes (or always) the model is written on the coil.So if you look thru the side vents you should be able to see what is written on the coil.(i think it's a SSD, because the newer Q's don't have a vent.)(but i don't know for sure.) Edited April 10, 201015 yr by kirill007
April 10, 201015 yr Normally you should see it if you push down the cone, and look thru one of those vents you can see something written on it.something like: SSD D2.Or something like that.
April 10, 201015 yr Now it looks like the older verison of the SSD Edited April 10, 201015 yr by BaMF101
April 11, 201015 yr Author Yes indeed sir u were correct haha. I appreciate all the help with that cuz I woulda nvr known where to look to find that out. So my next question would b that I'm thinking of getting a Saz1000d. Will that b too much power or will it b able to handle the little extra power?
April 11, 201015 yr SAZ-1000D will be perfect for your woofer. Set the gains properly and you should be good to go.
