Posted April 8, 201016 yr what do you guys think about 2 treo TE 10's run off an autotek mm1-1500d or the mm1-1000d? putting in this box 07 & Up New Body Style GM Crew Cab Dual Downfire Box in a 08 crew cab silverado.
April 8, 201016 yr what do you guys think about 2 treo TE 10's run off an autotek mm1-1500d or the mm1-1000d? putting in this box 07 & Up New Body Style GM Crew Cab Dual Downfire Box in a 08 crew cab silverado. I think it will be an average system, what do expect us to tell you?
April 8, 201016 yr Author i was just seeing if this would be a good sounding system for the money or if i should go another route.
April 8, 201016 yr What is your budget? What kind of music do you listen to? The more information the better as you have given basically nothing for anyone to help you out. Without goals or atleast preferences no one can give you a good answer.
April 8, 201016 yr Depends more on budget, goals and what all can fit. Give us more information, read the new member guidelines to see how to make an effective posts so we can help you out as much as possible.
April 8, 201016 yr Author my budget is around $1000 i have 2 memphis m3's 10's on a arc audio ks 1000.1 right now. i want something descently louder than what i have right for my daily driver. i listin to nothing but rap/hip hop.
April 8, 201016 yr I wouldn't replace your arc audio amp for an autotek. Are your subs in their recommended enclosure? If not, you could start by making a good one. And if that doesn't reach your goals, then get something different. Or if you really want to try something new. I think two incriminator audio lethal injections would go good off that power. Check out the store here there's a lot of good products that may spark your interest.
April 8, 201016 yr Author well would 2 treo te 10's sound better and louder of my arc amp than my m3's i have now?
April 8, 201016 yr Definitely keep the Arc Audio Amp unless you want to do some electrical upgrades to get more power from a bigger amp. What size enclosure can you fit, if you dont know then get a tape measure and measure your max dimensions (length x width x depth). What electrical upgrades have you done now? What kind of box are your subs in now, the box could be an issue as well?
April 10, 201016 yr Author this is the enclosure i was going to use from subthump.com for the two treo te 10's. 07 & Up New Body Style GM Crew Cab Dual Downfire Box
April 10, 201016 yr the treos will sound great i had two 15's the same model in a ported box good sound quality
April 10, 201016 yr Author should i run them off the current arc audio amp i have now or something new?
April 10, 201016 yr should i run them off the current arc audio amp i have now or something new?That is a decision you will have to make, its your money and equipment. I would install and see how it sounds then go from there, just my .02
