May 2, 201015 yr Author dude i need one of those im from texas shirts! born in dallas lol, anyways looken good bro cant wait to see the numbersHaha yeah i thought some people would get a laugh out of that shirt. I will have numbers soon enough. I should have this system bumping by Thursday or Friday.
May 2, 201015 yr on the shirt, definitely need 1 or 2 of them. Good luck on the numbers, what are your goals if any?
May 2, 201015 yr Author on the shirt, definitely need 1 or 2 of them. Good luck on the numbers, what are your goals if any?I am hoping for at least a 147+ on music outlaw style
May 6, 201015 yr Author What class are you in for Usaci?I will be in SB2 and stock 3000+ after this build is done.
May 6, 201015 yr Look forward to seeing some good scores!Im in trunk 0-1000, actually. Thinking about doing SB1, but we'll see.
May 6, 201015 yr Author Look forward to seeing some good scores!Im in trunk 0-1000, actually. Thinking about doing SB1, but we'll see.Why not a stock class? Any particular reason for running trunk 0-1000?
May 6, 201015 yr Author I like the build on smd better. haha jkselling that other 7k ?No sir getting it fixed an using it! Soon as i get it fixed i will be burping the subs with both amps, then at the end of the summer when i get my lvl 6 12s in i will be putting a 7k to each one. Yeah the build log on S M D is full of all sorts of lolz and is way bigger!NYYIIOOCCEEE!Thanks Edited May 6, 201015 yr by Cthedinger
May 6, 201015 yr Look forward to seeing some good scores!Im in trunk 0-1000, actually. Thinking about doing SB1, but we'll see.Why not a stock class? Any particular reason for running trunk 0-1000?Probably because I just started to really get into competition about a year ago, and I feel like its a good starting point. Not that its any less tough for me, though, quite a few people round here run in the same class. I still have a good way to go to get a score I ike, though.If I really wanted to, I probably could run stock, depends on who shows up to what, I guess.
May 6, 201015 yr Author Look forward to seeing some good scores!Im in trunk 0-1000, actually. Thinking about doing SB1, but we'll see.Why not a stock class? Any particular reason for running trunk 0-1000?Probably because I just started to really get into competition about a year ago, and I feel like its a good starting point. Not that its any less tough for me, though, quite a few people round here run in the same class. I still have a good way to go to get a score I ike, though.If I really wanted to, I probably could run stock, depends on who shows up to what, I guess.I see. I started competing back in December, I've always ran in either a stock or mod class.
May 8, 201015 yr Author http://www.youtube.com/watch?v=9jJNtluThQQhttp://www.youtube.com/watch?v=xY4SbBIEfjsI am ordering a line driver this weekend, box will be moved to the trunk as soon as i can get some help.EDIT: Part 1 added Edited May 8, 201015 yr by Cthedinger
May 8, 201015 yr Very nice equipment and box. I wish people would finish out their installs and make them clean. You're real close to having a sick setup. Hopefully you'll be moving that to the back and no going ghetto on us Btw did you rotate the subs partially on purpose?
May 8, 201015 yr Author Very nice equipment and box. I wish people would finish out their installs and make them clean. You're real close to having a sick setup. Hopefully you'll be moving that to the back and no going ghetto on us Btw did you rotate the subs partially on purpose?Yeah the box will be moved to the back soon as I can get some help getting it back there. And I put the first sub in and I noticed it was partially rotated, and there was no way in hell I was pulling it back out so I made the other one partially rotated the other way to make it look like it was meant too be.
May 8, 201015 yr Author Awesome excursion Yeah I was kind of hoping it wouldn't be a lot because its got some thick as spider and the box is smaller than what the DC site recommends.
