Posted May 6, 201015 yr got a sae1200v2 wired to 1.33 and my mids and lows running off a mb quart pushing 125x4 at 4 ohms will one run on 1/0 awg be enough and just split it inside the car or do i need more than thatthanks trying to order wire during 5 dollar shipping from knu
May 6, 201015 yr 0awg is good for 300a. Add up your fuse ratings of all your amps. If under 300a your good. I suspect you'll be around 200a assuming first amp is about 1200w and second is 500w.
May 6, 201015 yr like KU40 said YES you will be fine! but fast question what other equpiment do you have in your car? h/o? big 3? extra battery? beefy battery in the front? suv? lol do you have a voltage meter rather then a dumb gauge? sorrry just double checking to see if you got the electrical guts to backup the car audio! I assume you do but it doesn't hurt to ask to be safe!
May 6, 201015 yr Author got 2 of big 3 done will do + to alt when i get my knu wire in--- got a stinger voltmeter i got to find a place to put--- stock alt and stock battery- gonna buy a new battery when i get the cash to---probably either an xs or kinetic - then if that doesnt hold up h/o alt probably dc power one step at a time -- o ya got to do this in between lifting my truck up and buying new wheels and all terrians for the truck-- dam cant wait till i get paid every week instead of twice a month thanks for the help
