Ordered my amp! It's an old school Soundstream Tarantula monoblock. Specs are as follows:
Continuously Variable Low-Pass Crossover
Three Stage Level Input Indicators
Output Clipping Indicators
Phase Inversion Switch (0 - 180ᄎ)
Selectable Differentially Balanced Line Inputs
Fully Balanced PS-2 Input
Line Output
Gold-Plated 1/ ? Power Connectors
Discrete Balanced Class A Drive Boards maximize linearity on low impedance loads
Drive Delay 2? eliminates "turn-on" and "turn-off" pops and noises
Chassisink? Semiconductors are situated between the circuit board and
heat sink for optimal thermal transfer
Power Grid? design optimizes current delivery to and from the power supply
Tone Sweep Calibration optimizes the power supply to the connected speaker load.
All chrome plated
NUMBER OF CHANNELS 1
OUTPUT POWER (WATTS):
RMS @ 4 Ohms 2000 @ 12.6v
RMS @ 2 Ohms 2000 @ 14.4V
T.H.D.: <0.02%
FREQUENCY RESPONSE (Hz): 20 - 500
SIGNAL TO NOISE RATIO: >86dB
CHANNEL SEPERATION: >60dB
DAMPING FACTOR: >500
INPUT SENSITIVITY: 300mV - 5.0V
CROSOVER SLOPES: High-pass/Band-Pass 24dB
CROSSOVER FREQUENCIES (HZ): Low-Pass 35 - 500
HAWKINS BASS CONTROL (SUBSONIC POSITION): Variable High Pass (no boost) 13 - 30Hz
HAWKINS BASS CONTROL: (On position)
Variable Bass Boost 30 - 70Hz
Variable Bass Boost 0 - 9dB
DIMENSIONS (INCHES) : 19 x 14 x 5.5
Edited by johnecon2001
fixed pictures
dam how do i get the pics to show up? lets try this.
much better :)
Edited by RaTtLz
Fixed your first post
Thank you! what do i need to do in order for it to work the first time?
Nice Amp-I remember those in the day along with the Davinci. Hope to see pics once you get it installed. :woot:
Your pictures already had the %7Boption%7D tag wrapped around them. There was a second set on each picture that was basically canceling out the embedding process.
