May 18, 201015 yr Author Sounds like a plan, keep up the hard work.will do and il keep the pics and updates coming. Edited May 18, 201015 yr by lil98cabrio
May 19, 201015 yr Author looking good man. i wanna see some good numbers me too, im quite disappointed at the moment with the numbers i am getting . but it takes time to get it perfect.
May 19, 201015 yr Author what should i do today1. cut threaded rod and try to put in box while still in car.2. lay some sound deadener down on the rear doors.3.mess with the ports and pull out about a inch so there 4inches from back of box.4 try to do them all.5. go look at new winter truck.6. build box for the brother volkswagen7. give me idea what to do next. Edited May 19, 201015 yr by lil98cabrio
May 19, 201015 yr I personally would redesign the box differently. I would be glad to help just give me the external max dimensions. I would say lay some deadner today.
May 19, 201015 yr I vote 4!! GL man!! Seems like a nice build, just need to get it perfected. Why not but some bracing on the backside on the baffles? Might help with the flex. But either way man GL with it all!!
May 19, 201015 yr Author I personally would redesign the box differently. I would be glad to help just give me the external max dimensions. I would say lay some deadner today.yeah, i would like that. i have one idea but idea if id get better results from it. ill post a pic of the design.I vote 4!! GL man!! Seems like a nice build, just need to get it perfected. Why not but some bracing on the backside on the baffles? Might help with the flex. But either way man GL with it all!!hhaha i might try it if i get my buddy to come help. and im very limited with taking up space in the box thats why i went for addin threaded rod.
May 19, 201015 yr Author going to draw it up in sketch up tonight and get the wood and probably start on it next week.
May 19, 201015 yr Here are some pics of one of my first builds from the late 90's.... I was able to hit 148.6 off of 1000 rms from the Phoenix Gold M100's......
May 20, 201015 yr Damn that amp looks OLD!those amps were made in 1992. Dinosaurs of the audio world...There were 3 M100's and an M25. 2 M100's for the subs and one for the door speakers, and the M25 for the rear fill.....
May 20, 201015 yr Author heres one i came up with, would be 6 cubes ported at 32hz with 4 pvc pipes. and with subs and ports in i have .9 of a cube to add as much bracing as i need.
May 20, 201015 yr Author alright been sittin here thinking, do you guys think i could break a 145db with only using two of these and under 1000 watts?? and not burping. . Edited May 20, 201015 yr by lil98cabrio
May 20, 201015 yr Sorry for the thread jack but I have to chime in about those beautiful Phoenix Gold amps! I'm old enough to remember those and always wanted them but started a family
May 20, 201015 yr Author Sorry for the thread jack but I have to chime in about those beautiful Phoenix Gold amps! I'm old enough to remember those and always wanted them but started a family hahah thats alright man. and they are beautiful
May 20, 201015 yr You can easily break a 140 with two of them, you might need more than 1K but you will be close, it's all in the enclosure. Port area is your friend
May 20, 201015 yr Author You can easily break a 140 with two of them, you might need more than 1K but you will be close, it's all in the enclosure. Port area is your friend alright, well thats my goal at the moment is a 145 with 2 10's but trying to stay under 1000 watts. .the design im drawing up at the moment has 18sq ins of port per cube. should that be good?? Edited May 20, 201015 yr by lil98cabrio
May 20, 201015 yr That's going to be difficult with a daily driver ie. no modifications on the car itself.
May 20, 201015 yr Author That's going to be difficult with a daily driver ie. no modifications on the car itself.that why i set it as my goal, i dont want something easy to achieve. adn what kind of modifications are you talking?and only doing two give me room to change tings more easily. Edited May 20, 201015 yr by lil98cabrio
