Posted May 13, 201015 yr can i run my speaker wire and rca cables in the same door jam or do i need to run them seperate.power wire is seperate from rcas but does speaker wire matter or notanother questions trying to wire up my apline 6.5 coaxils how do i know which one is the postive and which one is negative or does it matter
May 13, 201015 yr it doesn't matter, you get buzzing from bad grounds.typically the ground is the - and the positive is obviously a +and when the connectors are directly into the speaker the larger tab is the + and the smaller is -
