Posted May 13, 201015 yr Have Everything Set Up For The New installjust need a design for the boxIm looking for A design for 2 15's Dual chamber roughly 10-11 Cubeswith measurements Around These...Height - 20"Depth - 26 "Width - 49"the design im leaning toward is subs facing towards the back of the seat with port underneath each sub.2 ports 1 for each chamber...
May 14, 201015 yr It shouldnt be a problem for his designer if he knows what he is doing, basically BanginGMC was just showing you an example of the box he designed for a recent build and not how yours will look. Just explain what you want and Im sure he will get you taken care of.BanginGMC, how much does he usually charge for designs? Thanks
